For Sale 82 650 Seca
Discussion in 'For Sale, Trade/Swap, Wanted' started by Ptrikk, May 6, 2015.
  1. Ptrikk
    Ptrikk New Member
    Ny
    My boss decided to sell our shop seca that I've been using all last year. I figured maybe someone on here would be interested. Its posted on ebay if anybody wants to check it out.
    http://www.ebay.com/itm/291449409230
  2. hogfiddles
    Purty
  3. Toomanybikes
    Tsawwassen bc
    Only bummer about US model bikes of that era 85 mph speedosstupid Feds and they thought ppl would drive slower hahahaha
  4. hogfiddles
    I swapped my speedo out for one that reads 115mph
  5. Toomanybikes
    Tsawwassen bc
    Great and you try to use all 115 of that of course
  6. hogfiddles
    Oops.... I lied---- it's 140mph
    Dave
    Toomanybikes likes this.
  7. Toomanybikes
    Tsawwassen bc
    You had to go and look . I have to be carefull with speedos the bikes I have older than 1976-77 are miles and newer are in kilometres ... But officer I forgot this old bike is mph. Same goes with my wife's car was a U.S. model and if I forget to switch to kph I'm in trouble( very fast car C6 vette)
  8. Toomanybikes
    Tsawwassen bc
    Was that just a faceplate swap or whole unit? Or a Canadian speedo with both.
  9. hogfiddles
    I swapped out from an xs750 triple.
  10. Toomanybikes
    Tsawwassen bc
    here's my bike. Any tricks with the coloured indicator neutral , high beam and oil light lenses starting to crack?
  11. hogfiddles
    Get a new front cover. It is POSSIBLE to replace just the lenses, but first you'd have to find them... And be extremely careful, otherwise you'll damage the cover and/or the new lenses .... And wind up buying a new cover anyway.
    Dave
  12. Toomanybikes
    Tsawwassen bc
    Haven't found them available new
  13. hogfiddles
    That's right :)..... Visit my favorite store--- eBay....lol
  14. hogfiddles
  15. Toomanybikes
    Tsawwassen bc
  16. hogfiddles
    Because you got it?
  17. Toomanybikes
    Tsawwassen bc
    Found 2 others listed not much better than the one I have
  18. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
  19. ecologito
    NASCAR Country, NC
    Dave, how is your seca coming along?
  20. Toomanybikes
    Tsawwassen bc
    Saw those ones can't tell from Pic if there any better than the one I have
    Seca runs great just a few things to pick up to make it really nice and tight
    ecologito likes this.
  21. hogfiddles
    I'm almost ready to repair the shock mount ends, then I can attach the shocks. It'll be nice to see it actually articulating correctly again.......(for those who didn't know, a PO had broken the ends of the upper shock mounts off almost flush to the bottom of the threads, and in order to keep the shocks on, had welded the top rings of the shocks to the shock mounts. Needless to say, that rendered the shocks to nearly ineffective because they couldn't pivot.)
    Then, I'll clean the tank and paint it a basic grey for a starting point......the ugliest thing is the rubber-sheet seat cover. I do have to finish the connections in the headlight bucket. Then I should be pretty close to trying to fire it up.
    Dave F
  22. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Dammit! All of your gages look better than the gigantic "Atari" unit. What the hell were the designers thinking? My Seca has sooooooo many square bits that need to be round! Headlight, turn signals, gages... sigh. So much to do, so little ca$h.
    Oh, yeah, the OP's Seca is sold!
  23. MattiThundrrr
    Wow, Dave. That sounds like a Previous Owner Masterpiece nominee! Is the rubber seat cover for scary moments when driving? Kinda like Depends for the bike?
  24. hogfiddles
    I hadn't taken a pic of it though.....PO claimed he rode it a lot, and just recently prior to my purchasing it---- yeeeeeaaaaahhh, rriiiiiigght.....
    Carbs gummed up, every jet solidly clogged, two slides stuck down, tires flat, tank w/ hole in it, shocks welded to studs....sheesh.
    But, though rough.... There was a diamond in there. I'm getting close.
