82 maxim digital display
Discussion in 'Hangout Lounge' started by Hermitguy, Jun 30, 2016.
  1. Hermitguy
    Hermitguy New Member
    SD
    Craziest thing happened today. The digital display between my two gauages had never worked, ever. And I had read where this isn't uncommon w/ these bikes. Well all of a sudden, I turned the bike on, and that display is working perfectly. I don't know why, I didn't mess w/ any wires, or anything. Just started working on its own. Go figure lol
    Loose plugs can get jostled. There might also be a bad solder joint, or the polarizing film may have lifted and then dropped back into place. I would not say that systems monitor failure is common.
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    You must have done the XJ gremlins a favor at some point, and they were returning it...o_O
  4. hogfiddles
    Loose wire
  5. Jack Miller
    Jack Miller Member
    Northern Illinois
    Having spent most of my career as an electronic technician, I bet the problem is what we call a "Cold Solder Joint". They appear to be securely connected, but the solder will appear dull around the joint. The connection can come and go with fluctuations in temperature or vibration.
