82 Seca Tach not working???? Ideas...
Discussion in 'XJ Technical Chat' started by Robert Powell, Sep 2, 2017.
  1. Robert Powell
    Robert Powell New Member
    Fairfield, California
    Hey all, not sure if my tach needs to be replaced but it does not work at all. Any ideas beside just buying another one and installing it... Thanks in advance!!!
  2. Rooster53
    Bike runs OK with no other issues?
    Pull the rear cover on the Atari assembly and make sure you have 12V power to the tach - Br to B. Also check the continuity from the grey wire on the tach to the TCI 4 pin connector grey wire.
    If you have the 12V power and continuity (less than 1 ohm) on the grey wire odds are the tach is bad and will need to be replaced. You can check this thread on some further testing that might be done on the tach itself before purchasing a replacement.
    http://www.xjbikes.com/forums/threads/xj900f-tachometer-electrical.116090/
    Robert Powell, k-moe and Plug like this.
  3. Robert Powell
    Thanks a lot Rooster!!! Yes, bike is running pretty good. Info was awsome and I love this old bike, so thanks alot!!!
