Wanted 82 XJ650 Maxim Engine
Discussion in 'For Sale, Trade/Swap, Wanted' started by SpectrumFighter, May 12, 2017.
  1. SpectrumFighter
    SpectrumFighter New Member
    Virginia Beach, VA
    Was wondering if anyone has an 82 650 engine or know where I can get one? Mine needs to be rebuilt or replaced.
  2. hogfiddles
    How far are you willing to travel?
  3. SpectrumFighter
    Virginia Beach, VA
    About 300 miles from Virginia Beach, VA
  4. hogfiddles
    Oh, ok--I'm about double that
  5. SpectrumFighter
    Virginia Beach, VA
    Dang. I have heard that a 750 engine will fit in the 82 650 frame, what about the seca (650 and 750) engine in that frame?
  6. hogfiddles
    Same thing.....except the turbo
    Read the engine swap section of the information overload hour
  7. XJ550H
  8. Toomanybikes
    Tsawwassen bc
    You'll never regret putting a 750 motor in your 650.just make sure you use 750 carbs to go with it, makes setup a snap.
  9. hogfiddles
    650 midnight maxims were 1981…
  10. hogfiddles
    750 into a 650 swap is covered in the engine swap section…
  11. hogfiddles
    Also, the 1980 Engine s a little bit different than 1982 internally… If I remember correctly it's something to do with the output gears or something-
  12. XJ550H
    first question to seller would/should be for the motor vin.
  13. hogfiddles
    It 3on't really matter, just. For sticking an engine in, but if you ever have to do transmission work inside--that's where you need to know what engine it really is. Also, the "Midnight Maxim" is pretty much the same as a standard Maxim- except for a few specific parts-the color, trim and gold appointments are the big differences.
  14. vitovabo
    vitovabo Member
    NE Philly
    Do you still need an engine?
  15. SpectrumFighter
    Virginia Beach, VA
    No, found a 750 replacement.
    XJ550H likes this.
  16. Axldog
    Axldog New Member
    I have an 81 650 maxim. Good motor, needs tranny work.
  17. hogfiddles
    Umm... the tranny in inside the engine. Justify your reply, please---
  18. Axldog
    Axldog New Member
    Right. Engine runs fine. Neutral gate is out. 1st and 2nd pop into neutral. 21,000 miles and never laid down. Needs tranny rebuild.
  19. hogfiddles
    Maybe just a shifter fork is bent
