82, xj650 shim kit?
Discussion in 'XJ Technical Chat' started by sethoneal7, Nov 1, 2014.
  1. sethoneal7
    sethoneal7 Member
    Dallas Texas
    I can't find a compatible one. Does anyone know where I can get one?
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Shims for what, valves? Why buy an entire shim kit when you may only need one or two shims?
  3. sethoneal7
    sethoneal7 Member
    Dallas Texas
    Valves, and because its easier than measuring and buying.... measuring and buying
  4. Bigshankhank
    Bastrop, TX
    Ok
  5. FtUp
    FtUp Well-Known Member
    pacific northwest
  6. patmac6075
    patmac6075 Active Member
    MKE
    Obviously, the choice is yours, but if you go around and measure each valve clearance and then pull each shim and record it's value...you'll have a record for future reference, plus you can then order only the shims you need and perhaps a shim you pull from one bucket will be reused in another....ultimately saving you both time and money.
    Stumplifter likes this.
  7. hogfiddles
    All you have to do is get a kit of 29mm shims..... They're all over the place. If you can't find a "compatible kit", you're not looking.
    A kit will cost you a fair bit--, but if you simply take your measurements, then swap what can and buy the few remaining ones, it'll cost very little.
    But, since you want a kit, Dennis Kirk, yamaha dealer, eBay, xj4ever, bikebandit........ And more, just contact them.
