Wanted 82 XJ650R Left Handlebar Switch
Discussion in 'For Sale, Trade/Swap, Wanted' started by firebane, Jan 22, 2019.
  1. firebane
    firebane Active Member
    Calgary, AB
    Any local Canadians possibly have a left handlebar switch? Yamaha part #4H7-83973-00-00. Choke lever needs to work and no breaks in cable support.
    Hoping to stay North of Border due to exchange and shipping.
    I'm located in Calgary and can pay through EMT, Paypal or cash if you are local.
    Reference picture: https://i.ebayimg.com/images/g/L9gAAOSwvApaAomY/s-l1600.jpg
  2. Toomanybikes
    Tsawwassen bc
    Same as the maxim part number
    I should have a couple of them
    I’ll check in the morning
  3. firebane
    Calgary, AB
    Appreciate it.
  4. Toomanybikes
    Tsawwassen bc
    Sorry but have everything but XJ650 Lh switch.
    Check with @hogfiddles . I have done business with Dave many times. Great guy!
  5. Toomanybikes
    Tsawwassen bc
    Oops found one but it’s missing the lever for signals but case and wiring is all there and choke lever is good
  6. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    NM
  7. firebane
    Calgary, AB
    Appreciate but with shipping and exchange it becomes pretty hefty. I'm keeping my eye for something in the Canadian regions
  8. XJ550H
    xj 550 will fit as well same part
  9. jayrodoh
    Cleveland
    He responded after that with a full unit minus the lever. If your lever is good you can swap over, clean and lube your contacts and mechanism at the same time.
  10. XJ550H
    toomanybikes is from BC that is Canada
    Toomanybikes likes this.
  11. firebane
    Calgary, AB
    Yeah, but there is the "what if". I thank everyone whose posted but I'm looking for something I don't have to mess around with. Thought I'd come here first to support forum members :) Before branching out elsewhere as I've had good luck here before.
  12. XJ550H
    the controls on a 550 or 650 bike are the easiest part to refurbish. pinpoint solder iron, eraser, electric spray cleaner silicone spray or dielectric grease.
    a horn/starter button is an expense if needed, sheathing for wire.
  13. Toomanybikes
    Tsawwassen bc
    I’m just south of Vancouver
    Tsawwassen to be precise
    Just swap lower case if that’s what is broken
