82 XS400J Oil Press. Lite not working
Discussion in 'Other Motorcycles' started by vincentmoy, Jul 20, 2009.
  1. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Hi all,
    I got a XS400J 1982. My Oil Press. Lite is not working. Gnd the wire w/ a tester and the light will go on. Got a new switch in but the lite still won't work (unless I gnd it will a tester).
    I'm outta clue.
    Anyone think of anything? I don't seems to have press. problem tho.
  2. bill
    bill Active Member
    Raleigh, NC
    Check your wire continuity from the switch to the light - may be a break.
    Have a request - can you post up a good pic of both side panels installed on your bike? I am missing mine and may just fab something but I have yet to find a decent pic. Thanks
  3. bigfitz52
    Isn't it an "oil level" indicator like the other bikes, not "pressure?"
  4. bill
    bill Active Member
    Raleigh, NC
    yes it is level Fitz I should have pointed that out
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Ours is pressure fitz :) i can take some pics of my side covers and post em up tonight for ya if Vince doesn't.
    Edit: the '83 at least is pressure. Comes on when ya turn the key, goes out when engine running, all from center stand.
    Just checked, the Seca service manual for '82 says pressure as well.
  6. bill
    bill Active Member
    Raleigh, NC
    The level lights do the same thing. Light is on when you turn on the key and shuts off when started. The XS400 manual does state pressure switch though - interesting
  7. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    But since when I gnd the wire, the light will goes on, isn't that means the wire is good? (If the wire is broken, there shouldn't be any signal going to the lite itself at all. right?)
  8. bill
    bill Active Member
    Raleigh, NC
    Yes IF you are grounding it at the switch - I did not want to assume.
    I have not had mine out - does it have 2 wires - hot and ground or does it get ground from the engine as it is mounted? Could be bad grounding.
  9. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Yes I grounded it from the switch.
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Ah crap bill, forgot the wife has all the memory cards out west with her. I'll have to wait for awhile to get those pics :/
    Are the ones in my gallery too far away to use?
  11. KrS14
    KrS14 Active Member
    St Marys, Ontario
  12. bill
    bill Active Member
    Raleigh, NC
    Excellent - they are even the right color- want to sell :lol: JK Thanks!
  13. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Heh if the motor ever blows i'll take ya up on that :)
