82 Yama xj750 condensation in engines
Discussion in 'Hangout Lounge' started by Frank Minneci, Jan 4, 2023.
  1. Frank Minneci
    Frank Minneci New Member
    Burlington nj 08016
    Hello all,
    Yesterday I unscrewed the oil cap and I found a white cream type build up on the inside of cap and a water bubble??
    I cleaned the cap real good I’ll check it today?
    Any ideas?
  2. Toomanybikes
    Tsawwassen bc
    If your not running a stiock airbox then moisture may be entering through the crankcase vent or your bike has been parked a long time and just condensation from wet climate
  3. Frank Minneci
    Burlington nj 08016
    Ok thanks. Would some marvel mystery oil help or just take it out for a good ride ??
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I wouldn't ride with contaminated oil. Change it first.
  5. Frank Minneci
    Burlington nj 08016
    I did 2 oil changes and filters also engine flush
  6. Frank Minneci
    Burlington nj 08016
    I was thinking to put a few ounces of marvel mystery oil in
  7. Fuller56
    Fuller56 Well-Known Member
    It won't hurt to use the MM oil. If you have freshly changed oil a good long run at operating temperature should clear it out.
  8. Frank Minneci
    Burlington nj 08016
    Thanks fuller 56. I did that yesterday ran awesome it’s clearing out the white jelly
