83 xj750 seca
Discussion in 'XJ Technical Chat' started by Gary1983xj650, May 9, 2020.
  1. Gary1983xj650
    Gary1983xj650 New Member
    Ogden ut
    Only 6204 original miles been sitting with oil drained what should i do before installing
  2. hogfiddles
    Before installing what?
    raskal likes this.
  3. Polock
    put the drain plug in
    hogfiddles likes this.
  4. Simmy
    make sure there is an oil filter in it.
    Also make sure the thin fender washer is there between the rubber filter grommet and the spring.
    XJ550H likes this.
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    After all that pull the plugs and crank it on the starter for 20 seconds, three times within - oo I dunno, 2 minutes.
  6. hogfiddles
    Why?
  7. Minimutly
    West Wales, uk
    Without knowing how long it's been dry, anything that would get lubricant around the bearings without load would be good, come to think of it I would also squirt some oil in each plughole. It's likely they'll get fouled at first start, but so what, lubing the bores and would be more important.
  8. XJ550H
    drop some oil down the cylinders first then hand crank the motor
  9. hogfiddles
    Oh, I thought you were trying to something to the starter.... I would lube cyls then turn it by hand rather than the speed of the starter....
