'85 XJ 700 Carbs
Discussion in 'XJ Technical Chat' started by Roys85XJ700, Jul 24, 2009.
  1. Roys85XJ700
    Roys85XJ700 New Member
    Charlotte, Michigan
    :?: Can anyone tell me what other make, model, and year I can use to get another set of carbs for my '85 XJ 700? :?:
  2. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    whats wrong with the ones you got?
  3. Roys85XJ700
    Charlotte, Michigan
    One of the post for the floats was broke and jb welded together and the smaller jets are seized in carbs. There is even one jet that is 117 and the other 3 are 36.5. The main jets are all 107. Just would like to have another set to replace these.
  4. Roys85XJ700
    Charlotte, Michigan
    I know they have to be from another maxim, I just would like to know if I can get them from a 1981-1984 650 or 750,or does it have to be a 1985,1986 700?
  5. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    From my research, I've learned that the xj700 carbs are very particular as to parts, and very few things are interchangeable. Plus, those carbs are hard to find! Best bet is to find a motorcycle junkyard somewhere and see if you can't scrounge up what you need. Ebay has them infrequently, and as soon as a set is posted, they're gone.
    Chacal (xj parts guy extraordinaire) has bits and pieces, but no full sets.
    You can try Sudco for jets, but they didn't carry the 36.5. I got one of the last few remaining 36.5 jets from chacal.
    Good luck
  6. Roys85XJ700
    Charlotte, Michigan
  7. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
  8. Roys85XJ700
    Charlotte, Michigan
    OMG I should have put the nic together lol How ya doin MM?
    yes I would like to replace at least the onw carb with the broken float mount. Thats why I was curious about swapping carbs.
  9. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    I assume you are talking about an airhead 700? (whith Hitachi carbs)
    opposed to the liquid cooled X with mikunis
  10. helmet
    helmet Member
  11. Roys85XJ700
    Charlotte, Michigan
    Yes I am talking about an airhead 700.
  12. Hydraphonix
    Hydraphonix New Member
    Merritt Island, Florida
    I have the same problem and from what I understand the 650 (non-turbo) and 750's have the same hitachi carbs but I'm not one hundred percent on that and would like to know myself. On EBay the look the same although I'm sure you will need your internals as the jets I'm sure are different.
  13. Hydraphonix
  14. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    According to a float level chart supplied by Chacal, the Hitachi 33's were used only on the XJ 700, the XJ 750 E-II, and the XJ 750 RL. I think the two 750's may have been imported to Europe, but not sure. Check this link and see the chart at the end.
    http://www.xj4ever.com/setting%20fuel%20levels.pdf
    Keep looking on Ebay, I see them all the time.
  15. tre66
    tre66 New Member
    coraopolis pa
    the carbs from the 81 to 84 xj 650 and 750 will not work on the 85 86 700 because they are different model hitachi's the only way they will work is you need to change the intake manifolds also,and as far as i know they are obsolete from yamaha.same with swapping the mikuni's from the watercooled 700x to the airhead you need to change the manifolds also.
  16. Hydraphonix
    I need new manifolds anyways so I might just do that. I see them on ebay Is that the only difference.
  17. Mcrider
    Mcrider New Member
    does anyone know if this works?
