85 xj700 Maxim. Can I raise the back end?
Discussion in 'XJ Modifications' started by erich, Jan 17, 2018.
  1. erich
    erich New Member
    oregon
    Picked up a running (poorly) xj700.$200 I've built both a Honda and Suzuki cafe bikes before. But looking at this guy. I'm not sure I'll be able to give the bike a flatter stance. Is it possible by raising the back end and lowering the front to achieve this?
    I plan to chop and Fab a new hoop into the frame and make a new seat pan. Leaving the rest alone for now. I can't seem to find any other xj700's "cafe'd"
    The u-joint has limits.
    The easy way to rais the rear is to fit a Seca rear wheel, which is taller.
    Quick Q; is your's aircooled, or watercooled?
    If it's watercooled, restore it to stock. Those are starting to be worth some coin.
    erich likes this.
  3. erich
    erich New Member
    oregon
    Is an inch up over it's limits? Seca parts don't seem to be a cheap find
    Air cooled. If it was an x I would definitely be keeping it the same.
    An inch will be fine, but I wouldn't go a hair more than that. All you'll need are longer shocks, or build the rise into your new rear frame by making the upper shock mounting studs sit lower and maybe a tad furher back.
    erich likes this.
  5. erich
    erich New Member
    oregon
    Thanks, everyone wants to make these into bobbers dropping the back end. I like flat bikes.
  6. erich
    erich New Member
    oregon
    As far as the drive shaft goes, is there different sizes for wheels? I found a few 18 inch wheels on eBay. Just not sure if they'll work
  7. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Maxim has 16" rear wheel, seca has 18". They will interchange as far as I know
  8. k-moe
    Correct. Virago, Venture, and XS wheels will also interchange, but look funny without a matching front.
    Chitwood likes this.
  9. erich
    erich New Member
    oregon
    thanks, i just want to make sure the brake and drive shafts are the same before i buy one or a set
  10. k-moe
    The rear drums are not all the same size, so be sure to get the brake plate along with the wheel. The Seca brake is larger than the Maxim.
