85 XJ700 pickup coil/Governor project bike.
Discussion in 'Hangout Lounge' started by donho41, Apr 9, 2014.
  1. donho41
    donho41 New Member
    Orange Park Fl
    I have a 1985 xj700 project bike I'm putting back together, I'm close to being finished and need some assistance. The pickup coil/governor is eather the wrong one on the bike or it has the wrong IC module on it. I have asked for assistance twice on this site and one member sent me the "manual" page with the pickup coil/governor on it ( which was cool and Thanks again). Help please.
    Thanks Donho
  2. bigfitz52
    It would help if you had the terminology correct.
    You said it's a "project bike" do you have a service manual?
    There are two pickup coils, mounted on the LH side of the motor.
    The TCI (ignition control "black box") is located under one of the side covers or under the seat, the Yamaha diagrams are inconclusive.
  3. donho41
    donho41 New Member
    Orange Park Fl
    Sorry about the terminology, let me explain. A friend of mine gave me the bike, it was running when he got it and he rode it to work for awhile. The bike had an electrical problem (I dont know what type) and he let one of his other friends "fix it", never got it running again. That's when he told me to come pick it up, title and all. I have gone through it and replaced some bad wires, new IC module. Sanded and primed, repaired the gas tank and a few other things. Now the pickup coil/governor is kicking my butt. I do have a manual and it has limited info about the governor. That's where I'm at. Donho
  4. chacal
    Make sure all your parts are correct:
    HCP12427H
    OEM Pick-up COILS AND HARNESS
    Resistance of each coil: 120 ohms +/- 10% = 98 - 132 ohms
    Applications:
    XJ700 all models
    XJ750-X
    HCP12427B
    OEM pick-up coils BASEPLATE
    the stationary plate only!
    marked 31A-10 and PU212-10
    Applications:
    XJ700 all models
    XJ750-X
    HCP497
    OEM Pick-up Coil ROTOR 1NH-81673-11-00
    the spinning disc
    originals marked 29R-10 or 29R-11
    Application:
    XJ700 non-X (air-cooled)
    HCP498
    OEM Pick-up Coil ROTOR 1NW-81673-11-00
    s/s from 31A-81673-11-00
    s/s from 1AA-81673-11-00
    the spinning disc
    originals stamped 31A-00
    Applications:
    XJ700-X (water-cooled)
    XJ750-X
    XJ900RK, RL, N/FN, F
    HCP416
    OEM TCI Ignitor Unit 1FG-82305-10-00
    small purple label lettered:
    TID14-44
    1FG-10 (date code)
    Hitachi, Ltd. Tokyo Japan
    Advance curve:
    7* at 1050 rpms
    ~18* at 2000 rpms
    ~27* at 3000 rpms
    ~33* at 4000 rpms
    37/5* at 5000+ rpms
    Application:
    HCP417
    OEM TCI Ignitor Unit 1AA-82305-10-00
    large yellow label lettered:
    IC IGNITOR
    TID14-35
    1AA-10 (date code)
    Advance curve:
    5* +/- 1* at 1100 rpms
    15* to 35* (??) at 2000 rpms
    40.5* to 45* at 3000 rpms
    40* to 45* to 4000 rpms
    39* to 44* at 5000 rpms
    36* to 41* at 8000 rpms
    Application:
  5. donho41
    donho41 New Member
    Orange Park Fl
    Awesome and thanks so much, I will be checking it this weekend, need to get the bike running, summer is here, again thanks.'
    Donho
