85 xj700n hsc33 carbs question ??
Discussion in 'XJ Technical Chat' started by denbola, May 7, 2014.
  1. denbola
    denbola Member
    poole,dorset,england
    can anyone tell me if the brass tube under the pilot jet be removed for cleaning ? as looks well in there thanks
  2. Rayz
    Rayz New Member
    Cr3
    If you mean the tube that the main jet needle slides into then yes.
    Once the main jet is removed the tube can be pushed out.
  3. hogfiddles
    First you must remove the slide and needle. Then you can push the tub out through the slide bore after removing the main jet and washer.
  4. denbola
    denbola Member
    thanks for reply rayz there seams to be a brass/insert tube under pilot jet, size 36.5 just can not get carb 4 to run right
