85XJ700 wethead Idle jet problems
Discussion in 'XJ Technical Chat' started by lbman, Mar 22, 2011.
  1. lbman
    lbman New Member
    NW WA
    well, thanks for the info. It looks like my only options are to get out the Idle jets' ! and clean those passages..
    someone or a lot of ----- have been working on carbs and the threads are goofed up. the #3 carb Idle jet only turns out 2 turns and gets stuck. not good when the info i have read says to start tuning at 2 1/2 turns out. I might have to dril a little and go the" easy out " before this is all over.
    close but yet so far away. OMG can a person put some time into these old bikes.
    LB
  2. lbman
    lbman New Member
    NW WA
    p.s. i have a 63 and 64 dodge powerwagons. OLD to say the least. and i have found a 50/50 mix of trany fluid and Acitone to be the best penitrating fluid. I think Marvels Mistery oil is tranny fluid. they smell simular.
    I use Marvels in my Gold wing have Never had to touch the carbs its and 82 with over 80,000 miles and has sat outside most of its life.
    fyi
    LB
  3. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    I have had good luck turning the screws all the way in, spraying a bit of carb cleaner on the top, then blowing out with an air gun.
    Then shoot a bit of penetrating oil in and unscrew them until they're too tight working them in and out a bit. After about 4 or 5 tries, I'll screw them all the way back in, use the carb cleaner again and blow them clean. Repeat until they come out. After about 5 tries I'll put them down and walk away otherwise you'll get too frustrated and loose your patience and strip those suckers.
