86 xj750 maxim starting issue
Discussion in 'XJ Technical Chat' started by mark j murray, Apr 3, 2015.
  1. mark j murray
    mark j murray New Member
    United States
    Hey guys im new to the site. Just bought an 85 maxim xj750. Nice condition but when i turn the bike on and hit the start button nothing happens. The headlight dims and the oil light comes on but nothing else. Also the neutral light doesnt come on when in neutral but the bulb isnt blown. Any thoughts?
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
  3. Rooster53
    It would be normal for the headlight to go out when you press the start button as the start switch contains a set of normally closed contacts for the headlight that open when you push the start button. If it is truly dimming, then as K-moe suggested below the PO might have gotten creative and changed the wiring. Also, if it is just dimming, what is the state of the battery? Do you hear any clicking when you push the start button?
    With no neutral light and the starter not engaging it might be a case where the safety circuit is deployed disabling the starter cutoff relay. The starter can only engage if the bike is in neutral or with the clutch pulled in AND the side stand up. Try pulling the clutch in with the side stand up and see if the starter will engage.
    Edit per K-moe's comment below
    But does it go out, or is it really dimming? If the headlight is dimming then someone has monkeyed with the electrics.
  5. mark j murray
    United States
    It is dimming. When i bought it the guy told me the safety switches had been modified. How many safety switches are there? I found one for the kick stand but is there one for the neutral switch? and where is the neutral switch on these bikes? I tested the battery and its good
  6. mark j murray
    United States
    There's no clicking. The solenoid is being engaged is the problem. Every bike ive worked on before always had two wires running to the solenoid also where this one only has a blue/white wire running from the start button? If anyone knows where i can find a wiring diagram for this bike i'd appreciate it. I havent been aable to find one
  7. k-moe
  8. mark j murray
    United States
    ok I WAS WRONG. My fault its actually an 86 xj700. I dont know why i thought it was an 85 or an xj750. But i cant find an xj700 wiring diagram on that link you sent me. Ill keep looking but if not i guess ill try that bare bones diagram. Thank you by the way! What i did was a tested the resistance between the blue/white wire at the switch and the solenoid. It should have been zero, as in there are no breaks, but it wasnt. So my next question is does anyone know where that wire runs to after it leaves the starter button? Im having a hell of a time trying to see it between the split in the links.
