91 fzr 1000 thoughts on buying.
Discussion in 'XJ Technical Chat' started by snowwy66, Jul 11, 2010.
  1. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    since you all gave me some valuable insight on the 99 ninja za11 i was thinking of buying. saved me the hassle of buying a bike with poor lubrication qualities.
    any insight on the y amaha fzr1000 motor. specs look like it's more power then the ninja 1100. but the gas tank is 5 instead of 6 gallons.
    i don't see any mention of problems on that motor on google.
  2. Hillsy
    Hillsy Member
    Good strong motors on the FZR. They do wear out the emulsion tubes in the carbs quite easily / quickly which can make them bog down around the 3 - 4 grand RPM range. Other than that, they're a nice fast bike.
    Check out http://www.exup1000.co.uk/
  3. bigfitz52
    It's a Yamaha.
    Apples and Oranges to a Kawi. Bulletproof if properly maintained; be sure to check exactly what that involves (as in valve adjustment.)
    You should know what else to look for by now.
