A little metal like glue on oil drain plug
Discussion in 'XJ Technical Chat' started by tabaka45, Dec 23, 2017.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    my 85 XJ700N has just over 17,000 miles on it. I’ve had it for about 6,000 miles and this is the second oil change.. I run synthetic Mobil 1. When I pulled the drain plug it had some gue like substance that has a grayish metal look. On closer examination I found a couple of very small metal slivers. The oil I drained looks perfectly fine with no evidence of metal. The oil filter is clean and shows no evidence of metal. The spark plugs look perfect so I assume it isn’t running hot. I don’t remember seeing anything at the last oil change so I can’t compare. The only thing I’ve done “inside” the engine is valve adjustment and stator bearing seal replacement. Should I be overly concerned? The starts and runs great.
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I don't think I'd be overly concerned. Make a note somewhere and observe the drain plug next time you change the oil, see what it looks like and go from there
  3. chacal
    Are the metal slivers steel or alum/magnesium? A magnet will tell the tale..........
  4. tabaka45
    Brunswick, Georgia
    They were stuck to the magnetic tip on the drain plug. Very very small, but still visible.
  5. k-moe
    Nothing to worry about. The transmission gears will shed metal for a while, and your machine is (in tems of use) only about two years old.
  6. tabaka45
    Brunswick, Georgia
    Great. It runs too good to have to do any thing to it. Merry Christmas to all, and to all a great ride!
    75 degrees an sunny in South Georgia! . Eat your heart out you northern riders!
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    9F right now, forecasted high for Tuesday is -8F.
    Windchill doesn't count.
  8. k-moe
    I happen to like the cold, and the snow :)
  9. tabaka45
    Brunswick, Georgia
    Like New York—nice place to visit but I wouldn’t want to live there.
  10. hogfiddles
    Ouch
