A quick intro
Discussion in 'Hangout Lounge' started by Canadian Mojo, Oct 31, 2015.
  1. Canadian Mojo
    Canadian Mojo New Member
    Canada
    Since I just signed up I figured it was only polite to introduce myself before I dive into the search function.
    I just got given an '84 XJ750 which needs surprisingly little work; the front brakes are seized and the HT leads are cracked and leaking enough electricity that grabbing one while it's running is not a good idea. Everything else seems fine... heck, even the carbs were clean.
    This is my first Yamaha after a couple of decades of looking after old Hondas (and a brief stint dealing with an old and abused Suzuki GS850) so while I have a decent idea of what I'm getting into I figured it was a good idea to sign up and learn about all the little quirks of Yamaha engineering and how to deal with them.
  3. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    How are things going with your newly acquired 750? And what part of The Great White North do you call home.
    We would likecto see some pics posted too(we love pics).
    Welcome to the Forum.
    Alan
  4. hogfiddles
    Well, if brakes are seized, and coil leads are cracked, I bet the carbs aren't as clean as you think, either-----
  5. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Might as well figure on replacing the rear shoes also because they delaminate and cause the rear wheel to lock.
  6. MN-Maxims
    Saint Paul, MN
    The coils need to be replaced or repaired if your coil wires are shot. I elected to install Dyna Coils on my 750. They seem to work really nice. However if you want to replace the coil wires you can do so by cutting the coils open and installing new wires and epoxy the openings back up. Test the coil resistance before you do so to see if they are in spec or you will be wasting your time.
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard. The XJ mojo is a good brew as well.
    Gary H.
