AARRRGGH! FLOAT VALVES!
Discussion in 'XJ Technical Chat' started by superluckycat, Jul 21, 2012.
  1. superluckycat
    superluckycat Member
    United States of Insanity
    I just spent the last 8 hours trying to set the float height for new needles and float valves.
    The manual for my HSC33's say 1mm from the carb body: bull. Every time I got them close to 1mm they would start flooding. I had to set them at 2.5mm.
    I filled, checked, drained and adjusted the damn things at least 15 times.
  2. adrian1
    adrian1 Active Member
  3. superluckycat
    That's exactly how I did it.
  4. mook1al
    mook1al Member
    Talladega, AL
    Are you sure you have Hitachi's, and not Mikuni's?
  5. superluckycat
    Positive. I think it has something to do with the aftermarket float valves and needles. I didn't have this problem with the stock ones.
  6. bigfitz52
  7. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    Try bending the tabs the other ways measure and start again slowly going back to where it needs to be set to. That worked for me and I put days into setting my floats with very similar issues. Everything was clean and polished but I couldn't get the same measurement twice.
