adjusted floats and now running rich
Discussion in 'XJ Technical Chat' started by trickedout420, Jul 11, 2012.
  1. trickedout420
    trickedout420 Member
    Greenwood MO
    i adjusted float according to the factory spec using a float tube gauge, and when i got them all set to 3mm i put the carbs back on the bike and black smoke rolled out of the exhaust...im at a loss of what i should do now
    the carbs are clean, i couldnt get to of the drain screws out so i just measured from the other ones and set them that way. but the floats all hung the same height. i have the pilot mixtures screws screwed 2.5 turns out
  2. wizard
    Don't see hoe you could use the clear tube method if you can't unscrew the drains & setting the float by measurement just don't cut it.
  3. trickedout420
    Greenwood MO
    i can open the 2 outter screws on each side (1 and 4) i then measured it and set the 2 inners at the same height.. i measured the float height after i set the 2 outters and set the inners.. i cant get the to inner drain screws out. and i would like to be riding the bike this season instead of sittin on the side lines. ive already adjusted valves, clunk test, cleaned carbs, throttle seals, orings.
  4. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    Yep, you can't just guess!
    If you can't get the screws out (however I would bring it to a machine shop and have them removed and get new ones from Len) then you may want to try my method. Some of the guys didn't like it but it does work perfectly if you take your time and do it right..... Go here.... http://www.xjbikes.com/Forums/viewtopic/t=31559.html
    After you do the floats correctly then you still need to sync and colortune 3 times. Oh and did you already check your valves? If not then you need to do this first.
  5. BillThyCat
    BillThyCat Member
    Ottumwa, IA
    You can use the bowls from the outside cylinders on the inside ones long enough to set the float levels, then just switch them back to their original locations.
  6. trickedout420
    Greenwood MO
    you know whats funny is i just went to bed and my lady said why dont you just switch the bowls stupid..
  7. fintip
    fintip Member
    Austin
    Yup, was going to recommend the same thing.
    Also, worth noting: my floats sit at different heights 'dry' to get to the same level 'wet'. I tried setting them all that way the first time, everything was way off. Two are higher, two are lower. Don't know why, but that's how it is.
  8. superluckycat
    superluckycat Member
    United States of Insanity
    You can buy an EZ out kit for about $12. They work great.
  9. trickedout420
    Greenwood MO
    i will in the winter..but after buying the bike for 750 and dropping already 300 into it and i havent riden it yet except for the test ride..im getting itchy to just got out there and ride the shit out of it its been tagged for weeks but im down to final tuning...then over the winter im tearing the carbs back apart and replacing and deep cleaning everything seals nuts bolts
