Aftermarket turn signals won't blink...! Why?
Discussion in 'XJ Technical Chat' started by Iamwayno, May 29, 2016.
  1. Iamwayno
    Iamwayno Member
    MI
    I got an 81 Maxim 550.
    I installed a new headlight and turn signals on the front end...and everything worked great! Everything on both front and rear of the bike lit up and blinked like they were supposed to. But as soon as I went to the back to change the other two turn signals, I hooked them up to test them, and they wouldn't blink. Both front and back would light up but wouldnt blink.
    Any idea why this happens and how to fix it?
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Are they LED?
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    They are not drawing enough current. If they are LED this is why.
    If they are incandescent, the bulbs are too small. They need 27 watt bulbs in each to work well.
  4. Iamwayno
    Iamwayno Member
    MI
    They are not LED. Ill try and post a pic of what I got in a sec.
  5. Iamwayno
    Iamwayno Member
    MI
    So, should I just buy new bulbs before I try a relay or resistor? Not sure if thats what I need at all. I know nothing about electrics.
  6. Iamwayno
    Iamwayno Member
    MI
    Here's what I got.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    Pull a bulb out. The wattage should be stamped in the base unless it's a real cheapy Chinese bulb. If not high enough wattage then you will need to swap them out. Adding resisters is for LED, doing do to incandescent bulbs will result in a dimmer light.
  8. cgutz
    SE South Dakota
    Do they have amber bulbs? Not sure white turn signals are legal, at least in my state.
    Try to find higher watt bulbs but hope they don't melt the lense.
  9. k-moe
    They are probably 24W bulbs. 27W is more better.
    jayrodoh likes this.
  10. k-moe
    Yes. Just barely visible in the first pic.
  11. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    IIRC I had a similar problem. I think I bought 3 way light. Had to return them and get 2 way lights.
  12. Iamwayno
    Iamwayno Member
    MI
    Awesome. Thanks guys! Yeah there is an amber bulb in the housing. I opened it up and it was stamped saying it was a 23 watt. I'll start looking around for a 27 watt bulb that fits. Any tips on how to look/find such a bulb? I was going to check some auto part stores and maybe the bike shop down the street.
  13. k-moe
    If your local auto parts store doesn't have them, Amazon will.
  14. Iamwayno
    Iamwayno Member
    MI
    Oh yeah, I love Amazon. I have Prime and thats where I buy most of my things. Im having trouble find either the right type of bulb, or ones that tell the wattage and if its 27w. I think also looking for an amber bulb is making it a bit more tricky too.
  15. k-moe
  16. cgutz
    SE South Dakota
    Post a pic of the bulb, brand and number on it.
    It would be jury rigged but is there room in the housing to solder in a 4 watt bulb in parallel?
  17. Xjrider92117
    San Jose Ca
    Return them if you can. Get some different ones that are correct. Save you some$$$ to. Unless you really like those ones
  18. k-moe
    Returning the housing because the bulb is of a lower wattage will get him another housing with another underwatt bulb. Almost everything that isn't LED is sold with 23 or 24 watt bulbs anymore. IF it weren't for the funky (but cool) signal relay for the auto-cancel he could just swap in a different signal realy and be done.
  19. XJ550H
    buy a brand name replacment bulb.
    the blinker bulbs run in parallel to ground.
    easiest fix would be an adjustable after market relay the ones that will run led or standard bulbs
  20. hogfiddles
    Is the bike running, or not, when you're doing this? Many of the XJ's won't blink unless the bike is running, and the rpms are a little bit above idle
  21. Iamwayno
    Iamwayno Member
    MI
    Hmm....didn't know that. I'll try it.
  22. cgutz
    SE South Dakota
    A marginal battery can also cause blinkers to not work unless revving the engine. However, using proper wattage (27w) bulbs solved this issue for me.
