air box install
Discussion in 'XJ Technical Chat' started by Fongdingo, Aug 21, 2014.
  1. Fongdingo
    Fongdingo Member
    Charlottesville VA
    So I did not and have never taken the air box off a bike so im not sure how it goes back on.it seems to large to just go back in. Any suggestions from y'all on how this is done. The carbs are off.this is for a 85 xj700
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Tell me about it, on my 650 seca the Airbox has to go in before the engine. Don't ask me how I learned that.
  3. som1somwhere
    som1somwhere Member
    United States, Illinois
    dont quote me on this but on most xj's doesn't the airbox have to be installed before the engine? if this is the case for you. HAVE FUN! :D
  4. peganit2
    peganit2 Member
    Davison Mi
    I tried a lot of things before deducing that the airbox was the LAST major item to come off the bike, and I'll be pretty PO'ed at myself if I don't put it in first when I put my 650 back together.
    Sorry!
  5. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Oh sweet I got it . did not have to take it a part. Used some lumber and my foot.
  6. Orange-n-Black
    Memphis Area
    On the 85/86 700
    All you have to do is: remove the carbs, starter, clutch cable and clutch cable bracket(on top of clutch case). With top of airbox removed, insert from left side of bike and shove back towards rear of bike. It will pop right in.
    I've done it a couple of times.
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    I was amazed how tricky it was on the 550 to get it (and teh battery holder) in on a bare frame. Think I ended up squeezing the two things togther and lots of jiggling..
    J
  8. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Good to know, I tried every which way I could think of trying to remove it from my 86 XJ700 so that I would have more room to pull the engine, but I ended up removing the engine first anyway.
  9. andrewc
    andrewc Member
    guelph ontario canada
    Sounds like brute force got it for you.
    I once tried to remove mine from my xj650 rj and gave up for fear of damaging things.
    I just did it when I had the engine out for unrelated reasons.
