Air box
Discussion in 'XJ Technical Chat' started by Xjrider92117, Sep 22, 2013.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Hey just wondering if there was an ez way to remove the air box off a 82 xj550??
  2. slackard
    slackard Active Member
    Earth, Terran System
  3. Xjrider92117
    San Jose Ca
    Yup. Thanks thats pretty much the same way I was thinking. But I do think the bike is a little different.
  4. hogfiddles
    saws-all will get it out quick.......:)
  5. Xjrider92117
    San Jose Ca
    That it would. Haha
    The reason I was asking cause I just wanted to inspect it. I took the air filter out and saw a small narrow hole in the corner. Wasn't sure if it was supposed to be there or not.
  6. quebecois59
    I seem to remember one of bigfitz's previous posts talking about a small air filter at the bottom of the air box.I don't have any link, though, but i'm sure someone else will find it.
  7. quebecois59
    Found the post, it was about the Seca 550 airbox, there's a small filter in the air intake, at the bottom of the airbox.
    Yours is a Maxim 550, tight?
  8. Xjrider92117
    San Jose Ca
    Quebecois... Your is a maxim 550, tight???
    Right?
    Yes it is.
  9. bigfitz52
    When you say "small narrow hole" where is it exactly? It may be a drain.
    The Maxim airbox doesn't have the "snorkel" that most 550 Secas' have.
    I'd recommend you inspect the airbox in place. Removing it just for that isn't worth it.
  10. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    yea... the easiest way to remove the airbox (whole) is to pull the engine..... +1 on not worth it just to look at it....
  11. davec
    davec Member
    ontario canada
    lol hogfiddles
  12. Xjrider92117
    San Jose Ca
    Thanks for the replies. Well not gonna take the air box... To much trouble for probably nothing.
    Fitz the "small narrow hole" in the air box...
    If you pull the air filter out then looking in the box it would be in the left corner. under where the filter would be.
    But I think it looks to perfect of a hole to not have ment to be there.
    Thanks again everyone.
