air filter q?
Discussion in 'XJ Technical Chat' started by loolagigi, Mar 21, 2009.
  1. loolagigi
    loolagigi Member
    right now i have no air filter, or air box. i was just going to use the "bullet" shape filter 1 for each carb. where can i find those? ebay?
  2. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    ebay, but they are not recommended because you will have to re-jet the carbs
  3. loolagigi
    loolagigi Member
    thats another question i have. i am running open headers, wont i have to rejet anyway? and what jets come in a 550 maxim factory? and which size should i jump up to?
  4. BikeRanger
    BikeRanger Member
    Dundas, Ontario
    theres no real set size that you should put in, it all depends on how restrictive the heads are. how restrictive the pods are, you can get them on ebay. its alot of trail and error. i was going to go that what because to buy a new filter was 40 bucks but the pods were 30 bucks. but the hasle that i will have to go through it more then 10 bucks worth. there is a forum post that has a suggested size for pods and open headers. search that forum and enter "pod filter" as the keyword should be the first or second one just read through there. should help you good luck let me know waht you find maybe ill have a go at it when i get some more money (broke college kid)
  5. chacal
    Here are all the different stock carb specs (carb model numbers, jet sizes, tune-up info, etc.) consolidated into one happy little group of information, so you can print this out easily when you are working on your particular set.
    XJ550 Models:
    Years & Models: 1981-83 XJ550 Maxim North American models
    Carb Manufacturer: Mikuni
    Carb Series: BS28
    Carb Model ID: 5K500
    Main FUEL Jet Size: #112.5
    Pilot FUEL Jet Size: #35
    Main AIR Jet Size: #70 (non-removable, in carb throat)
    Pilot AIR Jet Size: #165
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #35 (non-replacable, in float bowl)
    Main jet NEEDLE ID: #4GN
    Main needle JET Size: #O-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Float Height: 21.5mm +/- 0.5mm (0.85" +/- .02")
    NOTE: the service data tag says 30mm, but we believe that to be incorrect.
    Float Height Measurement Reference Points:
    a) at the carb gasket base, without the gasket in place.
    b) on the float, at ???? (unknown)
    Fuel Level in float bowls: 2mm +/- 1mm (.08" +/- .039")
    Ilde RPM's: 1,200 rpms
    Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less:
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
  6. bigfitz52
    Wow. You need to do one of those for each carb type (sorry.) Is the 550 Seca different? 5K5 is Maxim, is there a 4U800 and are they different?
  7. loolagigi
    loolagigi Member
    i did not relize there were so many jets in one carb chacal. oh boy
  8. chacal
    Hey Fitz, you mean like this? :D
    Years & Models: 1981-83 XJ550 Seca North American models
    Carb Series: BS28
    Carb Model ID: 4U800
    Pilot AIR Jet Size: #170
    Main jet NEEDLE ID: #4GZ11
    Float Height: 21.5mm+/- 0.5mm (0.85" +/- .02")
    All of these "cheat sheets" for ALL models are listed over at:
    http://xjbikes.com/Forums/viewtopic/t=14692.html
