Air filters for XJ650
Discussion in 'XJ Technical Chat' started by tumbleweed_biff, May 7, 2008.
  1. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    I have seen listings of people selling caps that look like big thimbles as air filters for these bikes. I assume that these attach to the carb in place of the boots to the air box.
    Are these a good idea or a bad one to use instead of the normal filter? What advantage do they have (other than adding more shiny metal).
    Mike
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    You will get differing opinions on them but I think they are a bad idea. Simply because they decrease gas mileage and make it hard to get a smooth steady running engine.
  3. chacal
    Pod filters are a GREAT idea if you just love tinkering with the jetting on your bike constantly, all the time, until you get it right. You know, pulling the carbs on-and-off, replacing jets, maybe shimming the jet needle, etc. etc.
    Over and over and over again. You'll become a carb expert in no time!
    Everyone else, stick with the stock air cleaner and filter system. It works well and is cheap. If you want more power, you'll have to get a bigger bike!
  4. TIMEtoRIDE
    I'm switching back to an airbox, in my 750 Seca,which actually requires an engine removal. It gets 32 to 38 MPG, while my 900 with an airbox gets 46-50 with more power !
    Now my V-Star 1100 gets 53 MPG. 100 LBS heavier, fatter tires,( 205 on rear) gobs of bottom end torque, fewer moving parts ?
  5. Zookie400
    Zookie400 Active Member
    Connecticut
    just ordered my pods! looking forward to beating these carbs into submission.
    timetoride- i was able to remove my airbox with only pulling the starter, rather than the entire engine, had you tried that? it was still very tight, and required some bending but it came out undamaged.
  6. TIMEtoRIDE
    What bike do you have? Mine's 750 Seca, and I cut the frame in 2 !
    (and I hit 6 th gear without using the clutch!)
  7. Zookie400
    Connecticut
    82 seca 750
