Air Leak at Carb Holder, 550 seca
Discussion in 'XJ Technical Chat' started by garicao, Aug 17, 2016.
  1. garicao
    garicao New Member
    I have an xj550r seca that has an air leak on the engine side of #2 carb holder. I can’t seem to fix it. This is what i have tried:
    Bought new set of carb holders and paper gaskets, installed with Hylomar to 100 inch-pounds (~9 n-m) torque. Fail.
    Replaced vacuum hose---no change.
    Removed and cut a new gasket from sheet of (somewhat thicker) gasket paper. Again Hylomar, used per instructions. Intake flange lightly sanded by hand with 320 grit paper before assembling. Fail.
    Tried reusing old carb holder with Hylomar. Fail.
    Cut another gasket (i’m getting pretty good at this) and tried high temp RTV (at lower torque) with the new holder. Fail.
    Any ideas?
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    How are you detecting a 'fail' ?
  3. garicao
    garicao New Member
    When idling, spray carb/brake cleaner around the engine side of the #2 carb holder; revs increase. Doesn't happen with other 3 holders. Also, won't hold idle.
  4. a100man
    Bedford, UK
    Hmm. Is the bike fully warm when doing this ? Idle can be fickle when cold. I would try repairing old #2 with RTV, old inner tube or what have you, then one more gasket - no hylomar, but maybe some silicone grease if you have some.
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    You may have bad seals at the butterfly shaft. Have you cleaned the carbs.
    TheCrazyGnat likes this.
  6. garicao
    garicao New Member
    Both cold and warm. Hylomar is claimed good to 250C, silicone grease to around 200C---why do you prefer silicone?
  7. garicao
    garicao New Member
    Have run into that in the past, but this is leaking from the engine/carb holder joint.
  8. a100man
    Bedford, UK
    Good question, I don't really know.. I would use Hylomar at an oil interface and normally use nothing at the gas mixture interface other than the gasket. I guess in my mind the grease is softening for the gasket and it's rubber compatible.. Temperature is not an issue on the inlet.
  9. k-moe
    Can you pinpoint the leak more closely? Is is possible that the leak is at the YICS o-ring between the head and cylinder instead of at the intake?
  10. garicao
    garicao New Member
    No idea---i don't know beans about yics and have never had the yics access bolts off. How could you tell?
