Air screw clairifacition
Discussion in 'XJ Technical Chat' started by Madmur, May 9, 2010.
  1. Madmur
    Madmur New Member
    Cambridge, Ontario, Canada
    Is this correct for an XJ750 Seca with Hatachi carbs,
    Air screws in = more fuel
  2. Madmur
    Madmur New Member
    I DUNNO!
  3. chacal
    No, you've got it backwards........
  4. Madmur
    Madmur New Member
    ok thanks
  5. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I assume you are talking about the idle mixture screws...
    Turning the screws in (clockwise) = less fuel (because it blocks the orifice at the bottom more).
    Nice to see a fellow XJer so close too!
  6. RickCoMatic
    NO.
    AIR Screw IN = Less Air = Less Fuel (with it) = Lean
    AIR Screw OUT=More Air = More Fuel siphoned-up = Rich
    On that 750 Seca ... Don't do "Turns"
    Try "Depth"
    From the Top of the carb Housing -to- the Top of the Screw:
    Preset: 11/64ths.
    That might be on the Lean side.
    9/64ths might be "Money".
  7. MiCarl
    Technically it's not an air screw. While it's not a fuel screw either, it behaves like one - in = less fuel = lean, out = more fuel = rich.
  8. RickCoMatic
    http://www.cyclepedia.com/pilot-air-screw/
    Old timer's call them AIR Screws.
    A few refer to 'em as: "The Idle's"
    We call them Pilot Mixture Screws, ... correctly?
    I never called a Main Fuel Nozzle an Emulsion Tube 'til somebody else said that Technically that what they were called.
    Now, everybody thinks the Nozzle is a Tube.
    We do what gets the job done.
