airbox advice
Discussion in 'XJ DIY How-To Instructions' started by Scotty53, Nov 17, 2014.
  1. Scotty53
    Scotty53 New Member
    sheboygan Wisconsin
    What's the easiest way to remove the airbox on a 1982 maxim?
  2. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Easiest? Sawzall. I'm a newb but the only way I would recommend doing this is if your bike was in spec and running properly first. If you run into a problem then you're going to have to source a new one which will not be too easy.
    You could take off the front motor mounts and rotate the motor forward, then take a heatgun to the box to manipulate it out, I suppose that would be the easiest way to remove it and keep it intact.
  3. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    See this vid it will show you how to do it
  4. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    That showed a good finished product lol how were they removed though?
  5. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    I will try to search it and If I get it I will post it
  6. chacal
    Hint: it's the funky background music that makes it possible!
    Josh phillips likes this.
  7. Josh phillips
    Bettendorf, Ia
    Lol gotta be the music, must be easier with the carbs pulled I wonder?
  8. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    I think it'd be damn near impossible with the carbs in place.
    XJ AJ and darren ditmar like this.
  9. k-moe
    ITt's 100% impossible with teh carbs in place, if the intent is to keep the airbox intact.
    darren ditmar likes this.
  10. hogfiddles
    The EASIEST was to get the airbox out and leave the carbs in place is to let someone else do it. THEY will have to remove the carbs first, though.......then they can heat it with a heat gun and slip it out.
    I do it the next easiest way..... I remove the carbs myself, and then heat the airbox.
  11. Josh phillips
    Bettendorf, Ia
    Well I can take off the carbs. That's basically what I was getting at lol so pull carbs heat seals on box and pull off. Cool thanks guys.
  12. k-moe
    Actually you will be heating the airbox and folding it up so you can pull it out.
  13. hogfiddles
    Exactly
  14. Josh phillips
    Bettendorf, Ia
    Hmmm I guess that will make more sense to me tomorrow. I'm pulling that area apart tomorrow. Don't worry y'all I have many mechanic friends. They'll fix what I break but I'll keep you all informed haha that battery box was a son a bitch to get out.
  15. Josh phillips
    Bettendorf, Ia
    So forgot to follow up. Air box was a bitch lol tried with carbs on, not happening took carbs off still a big pain in the ass. It had an unfortunate ending. Anger lol took the hammer to it. No turning back now, ordered my pods lol
    dizzycow and Stormin like this.
  16. Josh phillips
    Bettendorf, Ia
    Pods are in. It's colder than Alaska at the moment here and my garage is unheated. Very crappy work area. So here's my next question. If I fit the pods on the carb now inside the warmth of my home will there be clearance to install all of it?
  17. hogfiddles
    It's gonna be the same parts that get put in the same places regardless of where you do the work, and regardless of temperature.
  18. Josh phillips
    Bettendorf, Ia
    I think you misunderstood me, do I have to install the carbs onto the bike then pods or can I bring my carbs inside put the pods on them and have enough room on the bike to slide them back in. I visualized it this morning. Think it'll be fine
  19. k-moe
    Carbs go on first, then the pods.
  20. Josh phillips
    Bettendorf, Ia
    Cool glad I got lazy and didn't do it tonight haha thanks for saving me an irritating moment lol
