Airbox xj550 1981
Discussion in 'XJ Technical Chat' started by Paul Fitzpatrick, Dec 15, 2016.
  1. Paul Fitzpatrick
    Paul Fitzpatrick New Member
    Wallasey UK
    Hi all,I bought a 1981 xj550 last year which has been rebuilt from the bottom up.It came with four separate koni style air filters fitted on each car.A mechanic friend advised me to fit the original air filter box and filter as the separate filters could make the engine run hot?I will take his advise however there are different airboxes fitted on variants of the xj550.Mine is a 1981 xj550 UK model.I did purchase one last year which was described as 1981 xj550 airbox but it wouldn't fit and looked like it was off another yamaha?Has anyone any ideas?Any reply will be answered.Thanks guys.
  2. Jetfixer
    Good move to put stack airbox back in ,BRAVO It won't run hotter ,but jetting can be difficult to get right with pods plus can cause problem to ride in the rain IE can suck in water easily . It maybe a little difficult to refit , I can't say for sure what the difference between a US/UK airbox would be . Perhaps you could post some pictures of the airbox you have , some members have a 550 might be able to answer .
  3. dkavanagh
    Rochester, NY
  4. XJ550H
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    If it's UK then probably it's a 'Seca' although we have surprising number of Maxim's that have been imported. Either way it will be a pig to refit with the engine in and impossible with the carbs on (I struggled on a bare frame!). BigFitz used to reckon you could lean the engine forward by releasing some of the engine mounts to make it easier. Some even recommend softening with a hot air gun to make it more pliable. Good luck.
  6. XJ550H
    look at the vin for the model ID number US Seca = 4U8
    from
    TECH TOPIC: Model ID and VIN's
    550's
    1981-83 XJ550 Maxim USA: 5K5
    1981-83 XJ550 Maxim Canada: 5K6
    1981-83 XJ550 Seca USA: 4U8
    1981-83 XJ550 Seca Canada: 4U9
    COUNTRY: EUROPE
    MODEL NAME: XJ500
    STREET NAME: 1981 XJ500
    MODEL ID CODE: 5N4
    FRAME ID: 5N4
    SERIAL NUMBER STARTS AT: 000101
    COUNTRY: GERMANY
    MODEL NAME: XJ550
    STREET NAME: 1981 XJ550
    MODEL ID CODE: 4V9
    FRAME ID: 4V9
    COUNTRY: OCEANIA
    MODEL NAME: XJ550RH
    MODEL ID CODE: 5F9
    FRAME ID: 5F9
  7. Paul Fitzpatrick
    Wallasey UK
    Hi guys thanks everybody for your advice it's been a great help I'll start with the engine chassis/frame number that will give me a clue as to what airbox I need will post a pic of the xj550 shortly.
  8. XJ550H
    I was just searching ebay germany and it shows the swirly wheels for thr 550(seca) we have stright spokes in US on 550 Seca
    you will need a few more posts before you can post links and photos I think
  9. Paul Fitzpatrick
    Wallasey UK
    Ok thanks for advice.
  10. a100man
    Bedford, UK
    BTW UK 550 'Seca' is code 4V8..
  11. XJ550H
    and German 550 is 4v9,
    I would really like a set of swirly rims for my seca.
  12. Paul Fitzpatrick
    Wallasey UK
    Thanks a 100 man got swirly ones on mine painted red,nice!
    XJ550H likes this.
  13. Paul Fitzpatrick
    Wallasey UK
    Yeh vin number is 4v8 o1212
