Alternator to voltage Regulator
Discussion in 'XJ Technical Chat' started by Sinacopa777, Jul 1, 2025 at 10:47 AM.
Tags:
  1. Sinacopa777
    Sinacopa777 New Member
    Marshalltown, Iowa
    Does it matter the order of the white wires going from the alternator to the voltage regulator? I started make a new wiring harness and made the mistake of not labeling the wires correctly when I cut them. If it does matter, is there a way to determine which ones go to the correct connection on the regulator?
    From what I have seen it doesn't matter, but wanted to get others input on this.
    This is for a 1982 XJ550
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    does'nt matter , its a 3 phase alternator, all 3 wires should have the same output
    Sinacopa777 likes this.
