Am I screwed? (Xj750 Seca broken)
Discussion in 'XJ Technical Chat' started by Tafshaft, May 4, 2023.
  1. Tafshaft
    Tafshaft Member
    Canada
    I'm not entirely knowledgeable on motorcycles I just know a bit. I noticed my motorcycle making barely any power today so I brought it back to take a look and found this cracked.
    So uh... Idk what I'm looking at but is this severe?
  2. Tafshaft
    Tafshaft Member
    Canada
  3. Tafshaft
    Tafshaft Member
    Canada
    Doesn't look severe to me, when I opened it nothing fell out nor can I see any loose chunks.
    Still doesn't explain my lose of power, no I don't see any other holes in my engine and that crack could possibly be from the previous owner dropping it?
    Checked all spark plugs to check spark and all good.
    If the crack shouldn't be a problem what troubleshooting methods should I use to insure my motorcycle is in good running condition?
  4. Dan Gardner
    Minneapolis, MN
    If it’s just that cover that’s cracked then you are fine. Replacements can be had for a song and a dance.
    loss of power is a different matter…
    Tafshaft likes this.
  5. Tafshaft
    Tafshaft Member
    Canada
    What could possibly be the problems?
  6. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    Spark plugs behave differently when not under compression. Make sure all 4 header pipes are about the same temp, be careful not to burn yourself. A quick "slap" on them is usually wnough to chwck for even temperature. If one lr more are noticeably cooler, then you know which cylinder(s) are causing the issue.
    Franz and Tafshaft like this.
  7. Tafshaft
    Tafshaft Member
    Canada
    All 4 are hot
  8. Franz
    Is the pick up with the orange and black wire damaged? Not sure if it's sitting right might just be the camera angle.
  9. Tafshaft
    Tafshaft Member
    Canada
    Nope, nothing seems to be broken.
    Bike is still not running good, can't get it to start anymore.
  10. Franz
    If you have been cranking the engine and the battery voltage has dropped below 10 volts you will have no sparks at the plugs. You need 10 volts to operate the transistors in the TCI unit. Getting a spark now with the plugs out of the engine doesn't mean you have a spark under compression when the plugs are in. Do you have a multimeter you can set to 20 volts put the probes on the battery wires and read the voltage when you press the starter button?
  11. Franz
    You can also try and start the bike using a car battery and jump leads, keep the car engine off.
    Andrew Nichols likes this.
  12. Tafshaft
    Tafshaft Member
    Canada
    I got it running again only seems to be piston 1 and 4 are going but 2 and 3 aren't. (According to the headers)
  13. Tafshaft
    Tafshaft Member
    Canada
    I guess a very loose connection made this cable get undone ending up in two out of four cylinders running.
    I was really contemplating if engines are my forte since I'm still learning lol. Glad I didn't give up.
  14. short_circutz
    Glad you solved it. And learned something new. None of us started out as experts. It's a learning process. :D
