Another carb question...I swear I searched first
Discussion in 'XJ Technical Chat' started by Obiter_Dictum, Jul 18, 2011.
  1. Obiter_Dictum
    Obiter_Dictum New Member
    Winnipeg, mb
    I just tore apart my Hitachi carbs and to my pleasant surprise, they were, for the most part, very clean. However, in the number 2 carb there was a relatively thick and seemingly fresh layer of varnish. I am at a loss as to what could cause this to happen to only one of the 4 carbs while the others were as clean as a whistle.
    Any ideas?
  2. unknown
    unknown New Member
    Sparks, Nevada
    Honestly I'd love to know that as well, I also own an 83 XJ750 maxim, the first time I did a carb cleaning on it after buying it, the ports and what not on all of the carbs needed cleaning from the pink build up in the float bowls as expected, but were all relatively shiny, the same #2 carb on mine was grossly covered in black grime for some unknown reason. I cleaned it thoroughly and got it looking shiny. And just yesterday (or 9k miles later) I did a routine carb cleaning and didn't notice any buildup on either of the carbs at all. But still i would love to know why it was like that to begin with, or how it's possible to prevent it in the future.
    I was thinking it had to have something to do with the vacuum tube that goes to that cylinder/carb since that's the only difference between them to my knowledge. (at least on mine)
  3. bigfitz52
    If it's the carb with a petcock vacuum line on it, one possibility is a leaky petcock such that it's putting fuel into the vacuum line.
    Also, take a look at the design of your airbox. Is the breather input located directly below the #2 carb? What condition is your air filter in? A dirty air filter will make the carbs pull in more of what's coming in through the breather tube.
  4. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    It also seems like there are 2 different issues going on here. I have also gotten the situation where one carb has way more varnish than another. I believe that's because it's the one that receives fuel first from the fuel line. If it gums up, then the other ones don't really get as much gas after that.
    Where was the black grime on the carb? Black seems like a different situation to me, more like oil or dirt. I think the vacuum line thing is plausible because if your petcock isn't right, then either air or fuel could be coming through it, and either way it would cause problems.
  5. Obiter_Dictum
    Winnipeg, mb
    Thanks for the suggestion, I will definitely have a look at that. Though, when I had pulled the tank to do the carbs the pet**** did not leak at all.
    For further clarification, the varnish I am talking about was all in the bottom end (float bowl, fuel jets, etc), the top end on all of them was spotless with 4 solid clunks.
  6. unknown
    unknown New Member
    Sparks, Nevada
    Must be a different situation then, on mine the floats/jets etc. were the same as the others, it was the throttle valve and the piston valve that were covored in grime. I don't believe the vacuum tube on mine even works, the fuel will flow freely into the carbs without the engine running in both ON and PRIME. I also just checked the vacuum tube, it's completely dry all the way up to the petcock, so it doesn't leak back into the carbs, that's for sure.
    Previous owner had it sitting in a garage for 6 months before I purchased it though, that may have something to do with it, since I've purchased it, I haven't gone more than 3 days at a time without riding it and as I said, last time I checked the carbs after 9k miles of riding, all the carbs were in great shape, no buildup what-so-ever.
  7. bigfitz52
    How about under vacuum?
  8. unknown
    unknown New Member
    Sparks, Nevada
    Not sure what you mean, can you clarify?
  9. RickCoMatic
    Varnish accumulation means the Fuel is not leaving the Carb and Evaporating in the Fuel Bowl:
    There is an abundance of reasons why this might happen:
    Weak Manifold Vacuum
    Clogged Jets and Passages
    Air Leaks contributing to diminished vacuum
    The Primary Issue to be investigated is:
    >Manifold Vacuum
    Why is the Fuel being allowed to Evaporate in the No. 2 Fuel Bowl?
    Put a Vacuum Gauge on the offending Carbs Manifold and see if there is Vacuum?
    Report findings.
  10. Obiter_Dictum
    Winnipeg, mb
    My brand new gauge broke during the attempt to get the vacuum reading so will have to try again tomorrow, however, it seemed as though I was getting at least some vacuum at each one. Do I have to use the YICS tool?
  11. RickCoMatic
    YICS Tool ... Yes!
    Vacuum Restriction Devices ... Yes! (Needed. Or the vacuum Gauge fluctuates so rapidly and violently, ... it just might self-destruct).
    Fabricated "Restriction Devices"
