Another not starting thread
Discussion in 'XJ Technical Chat' started by Lokitruck, Mar 26, 2016.
  1. Lokitruck
    Lokitruck Member
    Bealeton,va
    im still having issues getting my bike started. Is there anyway to bypass the tci unit to see if it bad? I've had the valve clearences done. The carbs rebuilt and checked the electrical all the way to the tci unit. Everything electrical was in good shape. It just cranks and cranks.
  2. Polock
    send it someone with a running bike, see if it works in theirs
  3. XJ550H
    just to get some background
    Have you ohmed out the pick up coils?
    the ignition coil primary and secondary?
    the plug caps?
    tested the spark with a spare plug
    Hows the battery, have you done the cranking test to make sure you have the proper voltage to fire the Tci?
    fuel in the carb bowls?
    are your plugs wet after trying to start bike.
  4. Lokitruck
    Lokitruck Member
    Bealeton,va
    I did ohm the coils they were in spec and the plug caps were good. Ive not tested the spark with a spare plug. The battery was was sluggish so i hooked my truck to it. There was fuel in the bowls and my plugs were alittle wet after trying to start it
  5. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I would say it is a cranking issue
    aka you need a new battery
    you can charge it, but if there is not enough juice
    you will never get it started
    rocs82650 likes this.
  6. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Battery.
    Gary H.
  7. Lokitruck
    Lokitruck Member
    Bealeton,va
    Ok i was thinking the same thing. I hooked my truck up to it as a jump wouldnt that be enough to make it quick over?
  8. Lokitruck
    Lokitruck Member
    Bealeton,va
    Also i pulled a spark plug and ground it to the head and it was sparking.
  9. XJ550H
    that should work for you.
    are they new plugs?
    how cold is it in VA
    try some starting fluid
    if you leave the key on for a minute or two after trying to start bike do you get the expected back fire?
  10. Lokitruck
    Lokitruck Member
    Bealeton,va
    Plugs i bought new last September. I havent heard any backfire but to be honest i dont think i ever left the key on after trying to start it. The weather around here lately is mid 60's
  11. k-moe
    Not if one or more cells have a dead short. The battery will suck up the amps and act like a big resistor.
    Try jumping it with the bike battery out of the circuit (truck engine off).
  12. Lokitruck
    Lokitruck Member
    Bealeton,va
    So keep the truck hooked up but turn the engine off ? I will give it a shot when I get home.
  13. k-moe
    With the motorcycle battery disconnected entirely. Basicly, sub the truck batt for the motorcycle batt.
  14. Lokitruck
    Lokitruck Member
    Bealeton,va
    Oh ok I understand now. I'm at Easter dinner now I'll give it a shot when I get home.
  15. rocs82650
    Middle Tennessee
    +1.
    Gary H.
  16. Lokitruck
    Lokitruck Member
    Bealeton,va
    I had a motorcycle mechanic come to my house on Friday and after checking stuff my valve clearances were out some. I'm in the process of fixing that. However the mechanic was saying it seemed like the bike was out of timing. With him there we checked compression and spark. My compression was at 130psi in all 4 cylinders and I had good spark. I'm leaning toward the tci unit being bad.
  17. XJ550H
    test your timing
    get the valves in spec first
    Shim size
  18. Lokitruck
    Lokitruck Member
    Bealeton,va
    How do I test timing?
  19. Lokitruck
    Lokitruck Member
    Bealeton,va
    Well i got a new to myself cdi unit and i still cant get the bike to start. When i took the plugs out to put the new unit in, i did notice that the longer plug only had 4 wires coming out of it but the cdi unit had five prongs am i messing a wire?
  20. k-moe
    Firstly you are nowhere near knowing whether or not your TCI is bad.
    Secondly, what TCI did you buy?
    Thirdly you test ignition timing with a timing light, just like on a car. Do that.
    Then do this:
  21. Lokitruck
    Lokitruck Member
    Bealeton,va
    I bought one off ebay that matched the numbers off mine.
  22. XJ550H
    and its a 6 position connector. left connector i think black wire orange wire gray wire and a black white wire its ok to have an extra connection on the tci
  23. XJ550H
    if you have good spark your tci is working
  24. Lokitruck
    Lokitruck Member
    Bealeton,va
    I do have spark
  25. XJ550H
    have you considered a fuel issue? did you wet set the carbs?
    just had a problem where I put my spare carbs on my project bike and would not start there was fuel coming in through the main jet needles and flooding out the motor
    got it started with starter fluid
    but now I have to look at why fuel was flowing from carbs but not from overflow holes
  26. Lokitruck
    Lokitruck Member
    Bealeton,va
    I have not wet set the carbs so ill probaby be doing that this weekend.
