Another plug cap question
Discussion in 'XJ Technical Chat' started by texxgadget, Aug 9, 2009.
  1. texxgadget
    texxgadget New Member
    The patient in a 1983 Yamaha Seca 900
    Its a project bike coming back from the dead.
    I seem to have a spark problem.
    The shop book says promaries on the copils should be 2 ohms but i measure 5.
    If i unscrew the plug caps off the ends of the spark wires I get about 12000
    ohms on each which is in specs.
    Measuring the secondaries with the caps installed shows a momentary
    17000 ohm and then infinite on the coil for 1 & 2.
    This suggests a capacitor inside the plug cap ?
    On the coil for 1 & 4, it looks like one of my plug caps is showing an open.
    Is it possible to replace wires without replacing the coil ?
    Are there really capacitors on the caps ?
    Thanks in advance !
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    There are resistors is the caps. They are typically 5kohm. On some you may be able to unscrew the cap to access the resistor. Be alert as there is a spring, a disc and the resistor in there so you know how to put it back together once you clean it and/or replace the defective resistor.
    I've found it easier to just order a new set from Chacal :D .
