Anti dive hose question
Discussion in 'XJ Technical Chat' started by whitewolf_00, Jun 22, 2012.
  1. whitewolf_00
    whitewolf_00 Member
    Kirkland, Wa
    I know its recommended to replaced the brake hoses every so many years. The question I have is the anti dive hoses have to be replaced also? I looked on my bike that i'm restoring, and the dates on the brake lines are 1981. im assuming the anti dive lines are the same date. should i replace those also?
  2. Bushy
    Bushy Active Member
    Yep, if they go so do your brakes, it's all th same hydraulic system.
  3. MiGhost
    MiGhost Well-Known Member
    ++1
    The anti-dive works off the same line as the brake using a double banjo fitting. IF it goes. So do the brakes.
    Ghost
