Antigravity Battery
Discussion in 'XJ Technical Chat' started by Onetrackstu, Nov 15, 2013.
  1. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Anybody ever use an antigravity battery or have experience with them? I would like to use something smaller so I can hide it in the seat on my cafe project.
  2. Polock
    you don't need a anitgravity battery, just get some fresh dilithium crystals.
    your warp core will thank you
  3. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    yes i agree but I need the antigravity battery to initiate the warp reaction created by the dilithium crystals. ;)
  4. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    We dont have enough powerrrrrr captain!
  5. Polock
  6. FtUp
    FtUp Well-Known Member
    pacific northwest
    that's one pricy battery. they are very proud of what they have created. and don't forget the special charger required for extended battery life.
    CN
  7. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Ah very cool. I definitely consider that one.
  8. bigfitz52
    It has a three year warranty.
    Properly maintained, you can get 4 ~ 5 years out of a conventional, $39 wet-cell battery. I do it with great regularity. Longer even.
    If that battery lasts 4 ~ 5 years as well, then...
    I must be missing something. The maintaining?
  9. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    The maintaining isn't really the problem the thing is it has to be hidden under that cafe seat. I was thinking that a battery that is upright will not fit under it and if it's on it's side then the battery fluid would leak out. Otherwise the choice would be obvious.
  10. bigfitz52
    Gotcha. Then the one that Mr. P posted the link to makes sense. It's only an inch or so smaller in each dimension than the stock battery, but looks like it doesn't care about what orientation it's mounted in. I'm fascinated by the weight difference of the different technology.
    I you end up using one, keep us posted on how it works out.
  11. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Will do I'm not looking forward to the electronics. I'm still doing all the welding on the frame.
  12. Polock
    Fitz, next time your in a home depot check out the LI cordless drills. the first time i used one i wondered if it would ever die.
    the only reservation i have about them is the protection circuit. it stops the battery before it goes low enough to hurt itself. if your charging system was failing to charge the battery there is no warning, like slow cranking or dim lights. with a drill it drives the last screw just like the first then it just quits. that might not be a good thing on a bike
  13. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    I personally don't think that a LI battery is a good motorcycle battery. Reference this article http://www.newark.com/pdfs/techarticles ... /LIBMG.pdf
    They have a limited life and decrease the amount of charge it will take over time.
    The reason HD and Lowes and others sell the LI tools rather cheap is they make it up on the price of the replacement batteries. Guess they learned that from the printer companies...
    Also the life span of these batteries is from the manufacturing date, not when you first use it. So if the battery is a year old when you get it, you only have a year or so of life left in it.
    I rather stick with the $39 battery from Walmart..... :)
  14. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    What would be a good alternative that I could place in any direction?
  15. Rhettb3
    Rhettb3 Member
    South of the cities, MN
    I got an AGM scorpion battery online for $63, shipped super fast and no complaints so far.
  16. Polock
    vrla 12v/12ah i use a 10ah, they can mount anyway
    that article was written in '09 about lithium-ion chemistry check this out
    lithium-ions are the ones that explode.
    Yuasa batteries have no mfg warrinity, only from the dealer FAQ
    Bike Master has 2 year on gell and 1 on AGM and all others Bike Master
  17. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    I feel I should update this. Do not waste you money on this battery. I used it maybe 2x to start the bike and even charged it with its specific charger. After about 1.5 years of nothing being hooked to the battery, I went to test some things and it has no charge, it will not charge. I bought an AGM with 120 ccm, its bigger but I made it fit underneath my custom seat cowl. It is $30 vs $180.
    Stumplifter likes this.
