Any ideas where to get an M20x1.5x50 dental tube in the US?
Discussion in 'XJ Technical Chat' started by SQLGuy, Jun 16, 2022.
  1. SQLGuy
    SQLGuy Well-Known Member
    While reassembling my engine yesterday, I went to reinstall the oil cooler and spin-on adapter. To my chagrin I realized that the M20X1.5X50 dental tubes I had ordered for the center pipe that goes in where the oil filter bolt used to go were actually M20X1.75X50. Further, I so far have been unable to find the extra M20X1.5.X40 tubes from the set I had initially ordered and used.
    I had to destroy the M20X1.5.X40 tube when removing it (was held in with Loctite red) to be able to clear the frame when removing the engine, but I figured it would be a good opportunity to install the longer tubes, as the 40mm ones were a bit shorter than I would have liked.
    Anyway, looking around, I can't find a source for these things other than China. McMaster doesn't even have anything close. Any ideas?
  3. SQLGuy
    It's not a bike part. It's a custom part for my implementation of a an oil cooler that uses spin-on filters.
  4. Franz
    What are dental tubes? I am fitting the oil cooler adapter plate and bolt off a 900 Diversion, just need the machine shop to extend the threads a bit.
  5. SQLGuy
    Dental tubes are pipes that are threaded on the outside.
  6. Franz
    Never heard that term before thanks.
  7. k-moe
    We call them a close nipple where I'm from.
    Ask Chacal. The spin-on oil filter kit he sells uses them, though the length might not be the same.
  8. Franz
    This is the part l am using once the tread is extended.
    The Diversion oil cooler unit is the same l believe as the 900f so it will fit. I would have bought one from Len but would be too expensive. Close nipple is what they call them here too, just found them online.
  9. SQLGuy
    Mine is a custom oil cooler and spin-on conversion. I have no use for the stock bolt or cover.
    I think the difference is that close nipples usually have a hex bolster or similar, while dental tubes seem to always be one continuously threaded piece. I could use something with a bolster in the middle if it's pretty narrow and the overall length is at least 45mm... but I haven't found anything like that in online catalogs.
  10. Franz
    Some l see for sale are stainless steel which cannot be used in an aluminium crankcase.
  11. k-moe
    A close nipple is threaded the whole way along.
    Like so,
    The one that Chacal supplies has a notch machined in one end so it can be installed.
    His spin-on kits are made my a member here, so I'd think that it's be likely he could hook you up with what you need.
    Jetfixer and Franz like this.
  12. k-moe
    Well they can be, but removal will be....curse-inducing.
    Franz and Jetfixer like this.
