Any major differences between '81 maxim and '82 maxim??
Discussion in 'XJ Technical Chat' started by maybe4, Aug 27, 2011.
  1. maybe4
    maybe4 Member
    Chicago Area
    Thinking of buying a parts bike for my '82 xj650j. But the parts bike is an '81. Should I worry about interchangeability between the two?? Are they 99% the same or are there some significant differences?? anyone with experience with both of them??
  2. bigfitz52
    Are they both YICS motors? I think the '81 might be a pre-YICS bike, while yours has a YICS motor, doesn't it?
    Otherwise, pretty much the same. Use the fiche for cross referencing: http://www.yamahapartshouse.com/
  3. pbjman
    pbjman Member
    Algonac, MI
    82 is YICS, 81 is not. YICS is a different head with an open air passage between the combustion chambers, some sort of engineering wizardry that increased fuel effeciency without sacrificing performance. I think two of the intake boots from an 81 won't work on the 82 because the flange orientation is different on the YICS model. There might also be a difference between the tach output on the engines (one is gear driven, one is electronic, I think)
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    81 Non YICS & 82 is YICS. The Tach on 81 cable drive the 82 is electronic. Everything else is pretty much the same.
    MN
  5. maybe4
    maybe4 Member
    Chicago Area
    Interesting, thank you very much guys!
