Are 650/750 Carbs (off of 81-83 YICS Motors) the Same?
Discussion in 'XJ Technical Chat' started by mwhite74, Aug 31, 2012.
  1. mwhite74
    mwhite74 Member
    As per the subject,
    I'm looking at a 81 750 as a "winter project"... I know the carbs are both hitachis, but would they be the same model as what's on my 650? HSC-32s or HSC-33s? If so I know mine should be clean enough, would be great to have a second set or even another bank to clean up and keep/sell.
    Thanks!
    Marcel
  2. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    According to the Haynes manual, BOTH engines use the same carb set, HSC-32.
  3. maverickbr77
    maverickbr77 Member
    Lowville, New York
    same carb hsc-32, different jets though
  4. mtnbikecrazy55
    good call
  5. day7a1
    day7a1 Member
    San Diego, CA
    Different jets, AND DIFFERENT emulsion tube needles...check the catalogs, they have different P/N's.
    Not that changing jets and needles will contraindicate a second set of otherwise identical carburetors.
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Double check all the air jets also.
    MN
  7. mwhite74
    mwhite74 Member
    Wow thanks guys for the info! If anything its nice to know I'll have a spare bank of carbs, more or less!
  8. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    650 HSC32 carbs -
    Main jet: 110, Pilot jet: 40, Main air jet: 50, Pilot air jet: 195, Needle: Y-10
    750 HSC32 carbs -
    Main jet: 120, Pilot jet: 40, Main air jet: 80, Pilot air jet: 225, Needle: Y-13
    Needle jet is the same for both. 3.2mm
    Fuel level on both is 3.0mm +/- 1mm
    wgul likes this.
  9. TIMEtoRIDE
    I adapted 650 Maxim carbs for my 750 Seca by doing the above swaps.
    Kept me from having to do throttle shaft seal surgery.
  10. mwhite74
    mwhite74 Member
    That's my plan (if I get the bike that is). I can see that the ones on the SECA were leaky, although I've split a rack before it would save me some time for sure.
  11. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    +1 to Tskaz, for the elaboration.
  12. mwhite74
    mwhite74 Member
    Yep, thanks, this info will be handy!
  13. biggs500
    biggs500 Active Member
    Sherwood WI
    It's not hard. More time consuming than anything else. Good bonding experience with your ride. :)
