Are fork tubes interchangeable on XJ700N?
Discussion in 'XJ Technical Chat' started by tabaka45, Jul 11, 2014.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    My left fork is leaking (even after I had seals installed by a shop soon after I bought the bike). It appears that there may be a small nick in the tube that is causing the problem. I have a parts bike with a good tube on the right side. I assume the tubes are interchangeable, but just want to be sure before starting.
    Before you change out the tubes post a pic of the knick. Most of the time they can be polished out, or filled with epoxy.
  3. xHondaHack
    Orange CT
    I would think they are the same. However, make sure you have a donor one from an "Air cooled" xj700 though, as the X models had air assisted forks.
  4. tabaka45
    Brunswick, Georgia
    It is so small that it doesn't show on a picture. Smaller than a pin head and deep enough to feel . I've cleaned and filled it with JB Weld and polished it smooth but so far the leak hasn't stopped. It's just a slight leak so I've been wiping it every day or so, but now I want to get it fixed permanently.
    The parts bike I have is an air cooled XJ700.
  5. k-moe
    Did you also replace the seal? A knick will tear the seal.
    The upper tubes are interchangable from side to side. The one from your parts bike can be swapped into your lower tube (along with a new fork seal to be sure it doesn't leak).
  6. tabaka45
    Brunswick, Georgia
    I assume the nick was there before I had the seals replaced. If the spare tube is good and smooth then I'm going to use it along with new seals.
  7. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    What seals were used? I had trouble with after-market seals only lasting two years. Last time I put in OEM seals and two years later, still working fine.
  8. tabaka45
    Brunswick, Georgia
    I have no idea what seals the shop used, but I'll get good ones when I get time to do it. I've heard from others that some of the after market seals don't do well.
