Automatic Cam adjuster help!
Discussion in 'XJ Technical Chat' started by randall68, Jul 30, 2008.
  1. randall68
    randall68 Member
    I have been experiencing slack, and have been able to pull on cam chain and get slack when the valve cover is off...pulled the auto adjuster off and ratchet looks to work fine (holds when ratchet realesed etc) but.....i think it may have been upside down...i think the little pivot cam that holds the ratchet part in place was touching the block and allowing it to go back in...which drection does the teeth side go in..up..or down? mine was down??
  2. randall68
    randall68 Member
    Ok, I figured out which direction..only goes one way.....maybe its not fully protruding. I see marks on the teeth where it apparently rests and it's about 7-8 out of 20 teeth..thats less than half way up the tension arm.. meaning more than halfway to go.
  3. bill
    bill Active Member
    Raleigh, NC
    Haynes manual does not specify but the picture shows the ratcheting cam being up in the cutaway diagram
  4. randall68
    randall68 Member
    Tried it in the up position and it doesn't seem to fit right...
  5. bill
    bill Active Member
    Raleigh, NC
    OK - Like I said it does not specify which is a bit strange, Funny it shows the cam and teeth up if they go down but there are several errors in the book...
  6. randall68
    randall68 Member
    Ok, when i took the adjuster out I took 1000 grit sandpaper to the shaft..oiled it up..and re-instaled it. I did the method outlined by RickOmatic turning it counter clockwise then reversing it several times. Put the carbs back on and started it up. I guess somthing was boud up because no chain noise at all now! none! nada! weird hearing it that way actually because it has always sounded that way. Going to est drive it shortly and see if it chages..
  7. bill
    bill Active Member
    Raleigh, NC
    Cool My chain is tight but I still hear it spinning. Congrats
  8. randall68
    randall68 Member
    Well, I hear it spinning but not knocking...clanking...I had marks under my balve cover!
  9. RickCoMatic
    The crowd is actually standing on their feet ....
    What an ovation for Randall68
    I've never seen such a display of excitement
    They're still standing and cheering
    Here comes his marks for refinishing the shaft on the Cam Chain Tensioner and quieting-down the valve train noise on his Yamaha ...
    9.7 -- 9.8 -- 10.0 -- 10.0 -- 9.9 -- 10.0 -- 7.5 (Russian Judge)
  10. bill
    bill Active Member
    Raleigh, NC
    LOL Rick I love your sense of humor
  11. randall68
    randall68 Member
    LOL...Rick!!! There ya are! Me Bowing, head down....looking grateful.. :)
  12. randall68
    randall68 Member
    It goes down so I guess the manual is wrong on that one..
