back fire
Discussion in 'XJ Technical Chat' started by mustangc78, Aug 13, 2007.
  1. mustangc78
    mustangc78 New Member
    ct
    My 650 special II is back firing out of the right cylinder while driving between 20 and 45. But only wih a constant throttle. Should I back the air mixture screws out or go in with them? The screw right now is 4 turns out.
  2. RickCoMatic
    Might not be related to Mixture at 4 Turns OUT.
    If anything ... that would be a tad Rich.
    Measure your Intake Valve Clearances and do a Compression Test.
    You might have a Tight Valve or a Burned Valve.
    Hope for tight!
  3. mustangc78
    ct
    im running a bp7es spark plug. Should I go with a hotter plug? Will It help any?
