back shock part
Discussion in 'XJ Technical Chat' started by temperingloser, Apr 17, 2013.
  1. temperingloser
    temperingloser New Member
    paola ks
    just wondering if anyone knew where to get the parts that connect to the back shock both are broken and not even sure if they are worth replacing see attached pic
  2. mlew
    mlew Well-Known Member
    Apex, NC
    You talking about the grab bar right? Thats a salvage yard , EBAY item. Its up to you weather you keep it or not, some like them some don't. Either way you do need to completly remove your broken piece and proberly tighten the shock bolts before you ride again.
  3. temperingloser
    paola ks
    thanks just thought about removing them for now just wasnt sure wether or not it would effect the way the bike rode and paying a possible premium for them
  4. bigfitz52
    To clarify a tad: the piece that's broken, while strong, is primarily a "trim" item and not part of the shock's mounting to the frame. It USES that point as well, but with the broken grab rail parts gone, the shocks will still be solidly mounted to the frame (once you tighten up the nuts again.)
  5. temperingloser
    paola ks
    thanks again just removed them and tightened the nuts
