bad fuel mileage no power
Discussion in 'XJ Technical Chat' started by bambam629, Mar 11, 2010.
  1. bambam629
    bambam629 New Member
    alabama
    here we go my 85 maxim xj700 im getting about 50 miles on a tank of gas and im losing power i know that im only running on 1&4 just dont know why im getting spark to all four
  2. Lou627
    Lou627 Member
    Queens, NY
    Are you sure your carbs are clean? Has it been like this since you got it?
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Old chineese saying, "Sum ting wong" comes to mind. There must be a carb issue going on in there. 50 miles to a tank full? Ya, and no power? I can't think of where to start with that one. Maybe a brake is draging? Something must be holding it back or the engine is just plain running way rich.
  4. mlew
    mlew Well-Known Member
    Apex, NC
    Hopefully its nothing obvious like a bad fuel leak. I bet there is black smoke comming from your exhaust, way too moch fuel burning. Pull the carbs and clean them. Pay special attention to the fuel enrichment (choke) and float height.
  5. day7a1
    day7a1 Member
    San Diego, CA
    Strangely enough, you answered your own question. You are getting bad mileage and poor power because you are only running on 1 & 4. Next step, figure out why you are running on 1 & 4 only. Probably not solely due to the carbs, as it would be unlikely that 2 & 3 are completely gummed up but 1 & 4 are fine. My first guess would be weak spark on 2,3.
    It's possible to be getting spark but not have the cylinder fire. Before you pull your carbs, check the compression, spark plugs, coil resistance, maybe even run some seafoam through it to see if it helps. Pulling and cleaning the carbs is a big deal, and likely needs to be done, but doing it first when it could be the spark is simply bad troubleshooting.
    Sorry everyone, but it seems that carb cleaning is everyone's first thought here, but how would you feel (I would feel dumb as a rock, personally) if you pulled the carbs to clean them, only to discover your bike wouldn't run because you were out of gas. There's a reason we start with the simple things first!
  6. BlackMax
    BlackMax Member
    Brampton Ontario
    could also be a plugged up air filter...........
  7. BlackMax
    BlackMax Member
    Brampton Ontario
  8. TIMEtoRIDE
    A plugged air filter would fowl all 4
    You could double-check the coil by switching the little 2 wire connectors, and all 4 plug wires so that the 1/4 coil fires the 2/3 plugs.
    This double-checks the 2/3 coil.
    Then after switching the above back to normal,
    try squirting just a little starting fluid into 2 and 3 while running.
    Spray into the air box.
    This confirms that you need to "do" the carbs.
  9. prock
    prock Member
    Guelph, Ontario
    How does one spray fluid into just one cylinder? I asked how to use starter fluid a few days ago and was told to spray it into the air intake duct.
    What is the air box? The housing for the air filter and intake duct?
  10. TIMEtoRIDE
    With the air filter out, try to spray into the center 2.
    Sometimes you can put a carb cleaner straw into a starting fluid spray nozzle. You can also staple a small rag to a paint stir stick, soak it in gas, and wave it in front of your suspect carb inlets.
  11. bambam629
    alabama
    found the problem lil more drastic than i hoped but not life ending lol intake valves were not adjusted properly up and running again thanks for the help everyone yall ride safe
