Battery warning light
Discussion in 'XJ Technical Chat' started by maz43, Jul 16, 2011.
  1. maz43
    maz43 Member
    Detroit area
    My Battery warning light started coming on when I start my bike.
    It was working fine with the original sensor.
    Bypassing the sensor by splicing into the tail light wire doesn't work.
    Are there some other connections I can check out?
    Thanks,
    Maz
  2. Ltdave
    Ltdave Member
    my battery sensor (or should i say the wire that used to go to the sensor) is tapped into the positive terminal of the battery...
  3. maz43
    maz43 Member
    Detroit area
    I ran the sensor wire to the Positive terminal with no luck.
    Looking through my Haynes schematic showed a couple connections to check.
    The culprit turned out to be the connector in the headlight bucket.
    Cleaning it up fixed the problem.
    Maz
  4. schmuckaholic
    California
    1) Check the battery itself. Mayhaps it's low on electrolyte.
    2) There's always this little doohickey.
  5. Dymek5
    Dymek5 New Member
    Crystal Lake, IL
    schmuckholic
    Thanks that doohickey write up is "classic"
