battery
Discussion in 'XJ Technical Chat' started by bossone60, Sep 6, 2014.
  1. bossone60
    bossone60 Member
    battery not charging i have 81 xj750 seca any helh plz.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you need a multimeter (they're not expensive). test the voltage at the battery terminals ,without the engine running- should be 12v to 12.5v
    then with the engine running above 3000rpm should be around 14.5
    try that first then we can help further
    stu
  3. MBFTY
    MBFTY Member
    Lumberton, NJ
    You did replace your fusebox, didnt you?
    Is this a new battery or an old battery?
