BEFORE you fire up that welder READ THIS!!
Discussion in 'XJ Technical Chat' started by Mad_Bohemian, Oct 18, 2010.
  1. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Especially if you are 'teaching yourself' to weld PLEASE read this article ... it could save your life!
  2. Cmccully04
    Cmccully04 Member
    State College, PA
    great post. But you gotta be an Idiot to use brake cleaner to clean something and then weld it while its still wet anywayz. Not saying anyone deserved that, but well he definetly had that coming.
  3. Mad_Bohemian
    Ravenna MI
    I don't think he welded when it was 'wet'. As I understood it, he cleaned with the cleaner, then heated with a propane torch to evaporate any solvents , then welded. Even so... I would never have guessed that that combination - brake cleaner/heat/argon gas - could be so toxic and deadly.
  4. kirkn
    kirkn Member
    Orlando, FL
    Another pet peeve: burying IMPORTANT info in there along with just so much boilerplate.
    I mean, the safety warning reads like so much "do not pour brake cleaner into a glass and drink it off, do not puncture can by setting it on a post and plinking at it with yer .22 rifle, if you bathe in this stuff, it might irritate your skin..." but then buried in there is "cleaner and excessive heat MIGHT decompose into POSSIBLY phosgene"
    It's no wonder we're all so jaded when it comes to reading safety warnings.
    Do not drink... well, duh
    Do not shoot gun at can... well, duh
    Can decompose into phosgene... well, d... wait, what?
    << off soapbox >>
    Kirk
  5. schooter
    oh wow, we've done that alot on our farm, we just grab the nearest cleaner on a greasy or dirty spot spray it off and make sure its dry or wiped off, but never again
  6. TIMEtoRIDE
    That's good to know, and also,
    Stick welders make up to 2,000 unlisted toxins and carcinogens, depending on the paint or oils, or what not that contaminates your weld.
    Don't breathe the welder fumes at all costs, hold your breath if you have to.
    The man who welded the NASA crawler engines together, the engine blocks, piece by piece, gave me his old welding gear.
    Why didn't NASA just use General Electric train engines??
    That's your tax dollars at work.
  7. Zookie400
    Zookie400 Active Member
    Connecticut
    not since obama axed it, now its your privately funded and canadian tax dollars at work :)
    as for welding fumes....brake clean is dangerous enough (chlorinated or non) without the heat from a plasma arc. dont inhale the fumes.
  8. waldo
    waldo Member
    San Jose, Ca. 95125
    Holy Moly why didnt he just use MEK or tricoretheline like we used to do then we would drape asbestos fire blankets to keep from burning the place down. Guys lucky to be alive. I do admire him for putting the story out there for others though and thanks for posting MAD Bohemian.
  9. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Damn!
    That is insane and very scary. I will definitely be paying closer attention to my chemical warnings also.
    Damn bad luck for that guy for sure, I feel bad for him.
    Such a small, easily made mistake with a huge life changing consequence. Ouch.
  10. iwingameover
    iwingameover Active Member
    I saw that on Gears TV maybe two years ago. Crazy stuff.
