bi-passing starting circut cut-off relay
Discussion in 'XJ Technical Chat' started by jace5150, May 1, 2011.
  1. jace5150
    jace5150 New Member
    hello all,
    new member here. first off i must say these type of sites are really helpfull & everyones input helps out alot.
    ok i own an 81 xj 750. and i seem to be missing a relay & im wondering if there is any way to bi-pass it. my wires are located behind negative side of the battery. the colors are red w/ white stripe,blue w/ yellow stripe, sky blue, & maybe another redw/white stripe any info can help. i dont have spark is my main goal here thanks
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    connect the two red/wh together...problem solved
