Big problem - I lost the ignition key
Discussion in 'XJ Technical Chat' started by KiD_Vicious, Jun 3, 2012.
  1. KiD_Vicious
    KiD_Vicious New Member
    Hi!
    I am new here...and I have a BIG problem...I lost the only ignition key that I had for my Yamaha XJ550 SECA (1985)...When I lost the key , the ignition switch was in "ON" position...and still is...
    I need some ideas , how to fix or replace the ignition switch and gas cap switch ...with minimum damage...
    PS.:..sorry for my bad english.
  2. bigfitz52
    All you need is a LOCKSMITH.
    On the bottom of the ignition switch you should find a little label with the key code on it. A locksmith can use that to make you a replacement key.
    Be sure to disconnect the battery before removing the ignition switch.
  3. Kwiski
    Kwiski Member
    High Desert CA.
    I lost my key once. Had no label. So I removed switch & took to locksmith. Had two keys made so I wont do that one again. Cost me about $16.00
  4. Dougs82yamahaseca550
    Dougs82yamahaseca550 Member
    Portland, Oregon USA
    I had a key made on my 550 and all I had to do was look on the back side ot the ignition and saw 4 numbers which I gave to the locksmith. Cost me $10 or $15 bucks for a key and an extra.
  5. RickCoMatic
    Bring your Title to a Dealer or a Locksmith's Shop.
    They can access the Ignition Key's CODE through a secure online Data Base.
    You NEED to bring the Title or Valid Registration to have a Ignition Key Cut.
  6. KiD_Vicious
    Thanks very much to you all...I will search and contact a local Yamaha dealer ...this is the best option...I think...
    Before I lost the key...I tried to make a key copy at Locksmith's Shops near my town ...but nobody had a similar blank (key)
    If I don't resolve my problem with the local dealer....I will ask somebody from this forum ..to help me with a key copy from his local Locksmith's Shop... payment thru Paypal ...
    PS: sorry again ...for my bad English :)
  7. pbjman
    pbjman Member
    Algonac, MI
    Hi. Ebay and/or Chacal (here on this site!), has key blanks. You can order a couple from him and then get them cut if you have the code.
    I just went through a similar thing for a car. I didn't lose a key but because I only had one key, I knew I better get copies made. Since it was a GM VATS key (with a chip) I had to measure the ohm resistance to determine which blank I had then I ordered one online for $8 and had it cut locally. Dealer price would have been much $$ more.
  8. KiD_Vicious
    Our Locksmith's Shops are very rudimentary.... they have a carving machine ..but nobody has access to a online database... or any database... the code and the blank are useless around here...my only hope...a local Yamaha dealer...
    L.E.: The local Yamaha dealer told me that he can only provide me the blanks(that is good)...or the hole set , including all 3 new switches ..but very expensive.
  9. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Used to be able to gey keys with vin numbers in Ontario at one time. But only thru a master lock smith. But you can no longer do that. Take it to ANY lock smith and he can make a key. Just pull the ignition and take it in!
  10. Eddiesmith
    Eddiesmith New Member
    USA
    Cicero locksmith can make duplicate key for Yamaha XJ550 SECA (1985) in a very short period of time .They offer very affordable and genuine prices for top-notch locksmith services.
  11. XJ550H
    I went to a guy on ebay exceptional service 2 keys for 31.05$ including shipping with code stamped on them
    bel-ray64083
    Yamaha-Kawasaki-Suzuki-Honda-Keys-Cut-by-Code-Number
    consider a blank key cost $8 to $15 bucks
  12. Coty
    Coty Member
    Frisco city, Alabama
    I used the same guy as above off of eBay. Very fast shipping!
  13. hogfiddles
    It's not a big PROBLEM.... It's a big INCONVENIENCE.
  14. Rodrigosmith
    Rodrigosmith New Member
    usa
    When I got new keys cut from my ignition, it only cost me a bit over $100 including getting a couple spares from a local dealer.Then newt time when i lost my ignition key i contact to Berwyn Locksmith and they are very much affordable and are potential option.
  15. hogfiddles
    Wow, did they ever rip you off!!!
    $35 here....
  16. DrewUth
    DrewUth Active Member
    South Jersey
    Both my bikes were missing keys when I got them. Took the ignition switches and fuel tanks to locksmith and he made keys for all. Is it strange that my ignition keys do not open my gas tank- that the keys are different? A minor inconvenience but seems strange to me.
  17. hogfiddles
    Oh, ok. So, yeah--- with different cuts to figure out, that makes more sense.
    My bet is that tank, or at least the cap, was replaced. Seldom do I get bike that still has all-matching keys/cores anymore.
  18. XJ550H
    try finding a matching set then you can sell the odd ones
  19. DrewUth
    South Jersey
    I'm 99% sure that neither the ignition or cap were replaced, I have a feeling it is just due to the manner in which the locksmith made the keys in all honesty. I was more posting as a "caution"- as though I do have working keys, they are different. Which is really a minor inconvenience from having NO keys at all in reality, but I was curious if these bikes originally came with separate keys.
  20. XJ550H
    there are some key blanks that interchange it locks
    are your keys cut the same just different blanks?
  21. DrewUth
    South Jersey
    No- actually different blanks and different pattern. Its odd I agree. A pretty established lockshop that has done work for me like this in the past, so I didn't ask questions initially.
  22. k-moe
    They were all one-key-fits-all-locks bikes when they were first put together.
