Bike "jumps" when shifting from neutral to first
Discussion in 'XJ Technical Chat' started by prock, May 5, 2009.
  1. prock
    prock Member
    Guelph, Ontario
    Hi. When I put my 83 maxim 750 into 1st while standing the bike tries to "jump" forward a bit even with the clutch fully depressed. Is this an issue?
  2. Robert
    It could be that your clutch is miss adjusted (very common issue), but a fair amount of clunk in that particular shift is normal.
  3. SaltyCITYXJ550
    SaltyCITYXJ550 Member
    Salt Lake City, UT
    It may just be a clutch adjustment, or it may be severly worn clutch clutch plates. Try adjusting the cable first and see if that helps. If not you may be looking at a new clutch.
  4. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    I have the same problem. Only to first though. It only does it going into second on up if she's not completely warm.
    So how do you adjust the clutch cable? Its not like the throttle cable
    -SLKid
  5. SaltyCITYXJ550
    Salt Lake City, UT
    There is a series of nuts on a threaded end down where it connects the arm by your right foot.
  6. bigfitz52
    There should also be an adjuster at the handlebar end.
    The "clunk" going into gear is caused by clutch drag. Even a perfectly adjusted clutch will produce some drag, resulting in the "clunk" especially when cold. An EXTREME "clunk" or a persistent one does indicate the clutch is dragging and needs adjusting.
    Worn plates won't cause drag; they'll cause slippage.
  7. SQLGuy
    SQLGuy Well-Known Member
    If your idle is too high, you'll also see this behavior.
  8. JoeFriday77
    JoeFriday77 Member
    North Texas
    There was a post on here about clutch adjustment. I can't remember who posted it. I followed it to a T and it worked like a charm.
  9. RickCoMatic
    Search: Clutch Cable Replacement and Adjustment.
